Ive mirrored them here for you:
http://igmod.iamjeremy.com/cf14fonts
K, I can do the patching myself (you are refering to the transparencies, correct?) but I get some sort of arror when starting IGMOD, and it does not work. I think the error is a runtime error, but I forget. I do not have CF, and have not added the font, could that be the cause? Can someone provide a link to the font, I do not use CF but RR instead.Originally Posted by PURDooM
Michael
Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
Unlimited Internet and gps tracking for $6 a month with boost mobile!
Carputer 2: www.lmaocar.com
Your the man, can't wait to test it out later. Would that be the cause of the error, or was it because I did not do the manuel transparency patch?Originally Posted by PURDooM
Michael
The patch is completley unnessesary, its only to make things look visually better.Originally Posted by Wiredwrx
If your having an error the places to check are: You have write access to the iguidance registry key, and your runner.ini refers to the correct iguidance / skin paths
Where is the runner.ini, and how do I ensure that the registry key has write access.
I wish I had time to do a complete IGMOD/IG how to. Perhaps someone else can, or it can wait till sometime in the future.
Michael
The runner.ini is in the iGmod folder that you installed to.
I just installed Preview 3 and here are my observations:
1. First of all, IT WORKS! Pretty much. When I entered the first few letters of a city name or a poi name it wouldn't allow me to click on the name I wanted a couple lines down on the list to finish off the name.
2. Good thing I figured out I had to install the fonts listed above. I assume the final skinnable version will allow for alternate fonts.
3. A hard thing to see is the fonts on the lists. Is there any way to expand the listing shown above the osk when entering destination info?
4. Most screens that pop up obscure most of the map anyhow, why not make them all fullscreen to take advantage of the space and make them really readable? As it is now, a couple of them don't even cover the original IG popups completely.
5. When I exit RR, the window that I was displaying IG in is still left on the screen instead of my desktop icons.
Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
There is no runner.ini. I have a runner.bak only.Originally Posted by wysocki
Sooooo, I changed the extension, and viola, it works.
Wierd, now to DL the font, and check out the skin and stuff.
Michael
1. Thats because I don't know what your clicking.Originally Posted by wysocki
2. Its skinnable right now, but I don't want you to skin it because I probably am going to make some last minute changes to the skin before public release
3. Not that I know of. IG uses a custom control thats hard to read and write info to for stuff like that.
4. Because then I have to design a small and large menu for each skin. That doesn't sound very fun. Maybe if I stretched a default size...
5. Oh. Ill look at that tommorow probably. All I have to do is clean up after this party I threw and I have the rest of the day free. For coding hopefully![]()
So, I installed it, ran it, and it works, except there are lots of issues. I know it is preview, and sorry if this is a rehash, but,
The POI did not work. I get the skin screen that says something like "Default IM" or something, and then the button on the bottom to go back to the map. If I go back to the map, then the underlying menu structure for the POI us there. Also, inputing an address of cross street doesn't work. Not only can I not double click or hit enter , even though the list has found the street I mean, if the entire street name is not entered with the OSK, there is no way to enter the location to start routing, or see the map of the location once I have entered the entire name. This also happens with cross street locations. When I attempt to see a map or navigate, the program locks up.
That is all I have found so far, since that is really what I need the program for mostly.
Also, I would love to start skinning this thing, so let us know when you have the skinning worked out.
Michael
The logic for cross streets follows the same logic as the POI for making the menus, so when I have the POI stuff fixed the crossroads will fall right into place too.
