Page 24 of 63 FirstFirst ... 141516171819202122232425262728293031323334 ... LastLast
Results 231 to 240 of 626
Thread: iGmod Beta 2 release
  1. #231
    Jun 2002
    Virginia
    Quote Originally Posted by PURDooM
    Me and JIT are having issues embedding with the standalone mode disabled as well. Is that what your problem is?
    I looked at the windows that open when I have the problem and one says "IGMod Reloaded" and the other said "--IGMod Reloaded--". I changed the window in CF settings to "--IGMod Reloaded--" and it seems to be working. Could be I was just using the wrong window name. Ineed totest it some more.
  2. #232
    FLAC PURDooM's Avatar
    Jun 2005
    Anoka County, MN
    Quote Originally Posted by wysocki
    As I was driving around last night I noticed that a blank white screen flashed about every 5 secs and the speed zoom window would vanish as well. Don't recall this before but I wouldn't have noticed it in the day with a white background. I'll check it out more tonite.
    Will there be a way to trigger the "menu" without having the button on top of the map image? I'd like to have a menu button on my RR skin (outside the IG window) that would bring up the IGm menu.
    I drive ususally at night on a extremely slow computer and don't notice that flashing unless I am in the middle of making a turn. However, I don't use RR right now either, I should test that for a few days.
    How does RR pass information to iG? Keypresses? I could make hotkeys for buttons if needed.
    The problem is I have 2 windows named --iGmod Reloaded-- in memory if not using the standalone mode. Still examining this some more.
    Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
    Unlimited Internet and gps tracking for $6 a month with boost mobile!
    Carputer 2: www.lmaocar.com
  3. #233
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    I thought I was just loosing my mind, I am using IGmod with centrafuse and it flashes the square box at the top only when you have the map in night mode. It will not flash with the map in day mode, or if you drive under 10mph in night mode.
    肚子笑痛了
    S60 Install
  4. #234
    Raw Wave justintime's Avatar
    Apr 2005
    I have not noticed any flashes. What area are you refering to exactly? I use this at night every night, and honestly have not noticed.
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  5. #235
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Yes its done with keypresses. If you wanna make hotkeys for the buttons i'd suggest you take a look at iGkeys n use the same hotkeys. That way people that are using the zots skin can actually use iGmod
  6. #236
    Mar 2001
    Baton Rouge, LA
    I just installed iGmod and it looks great, but it's changing my tracks automatically. If i switch out of igmod, my track (whether mp3 or xm) stays.. but when I go into igmod, the track starts changing every 5 seconds or so.
    Anyone have any ideas?
    BTW, i'm running Roadrunner with MC2.0 skin.
    2006 Nissan Titan LE Truckputer
    [I]No installation thread yet[/I
    2002 BMW 330Ci Steel Grey Metallic *Sold!*
    Installation Thread
  7. #237
    May 2003
    Miami, FL
    Quote Originally Posted by justintime
    up at the top of the window
    肚子笑痛了
    S60 Install
  8. #238
    Jun 2005
    Anoka County, MN
    Quote Originally Posted by jcdillin
    OH i know.
    To determine if you are in guidance mode it checks pixel 0,0 on your map for the color dark blue.
    Which also happens to be the color of lakes and rivers at night.
    I recomend making the color slightly darker/lighter in your theme.ini if you can. Or wait until I have a creative fix for the problem.
  9. #239
    Constant Bitrate studmonk3y's Avatar
    Feb 2004
    Honolulu, HI
    hey purdoom love the program but quick question...I'm running igmod as an external app with frodoplayer, is there a way to have it remember it's window size to what it I had it set to? This isn't an issue with hibernation, but when I occassionally restart my computer and load igmod, I want it to be able to be the same window size I had it at before reboot, so I don't have take my mouse into the car and resize it manually. Keep up the good work.
  10. #240
    Jun 2005
    Anoka County, MN
    Quote Originally Posted by studmonk3y
    I think it remembers but it has to be a. non maximized and b. you have to close the program the correct way (press x, press yes i want to quit).
  1. iGMod Beta 1 release
    By PURDooM in forum Other Cool Stuff
    Last Post: 12-28-2005, 11:17 PM
  2. Release 1.4 CENTRAFUSE BETA 2
    By veetid in forum Centrafuse
    Last Post: 08-02-2005, 11:20 AM
  3. Release CENTRAFUSE BETA 2 (1.3)
    Last Post: 08-01-2005, 04:13 AM
  4. RELEASE - FreeDrive 0.51 Beta
    By CdRsKuLL in forum FreeDrive
    Last Post: 04-20-2005, 05:03 AM
  5. RELEASE - FreeDrive 0.33 beta (D3 Frontend)
    Last Post: 02-18-2005, 04:08 PM
