Page 35 of 63 FirstFirst ... 252627282930313233343536373839404142434445 ... LastLast
Results 341 to 350 of 626
Thread: iGmod Beta 2 release
  1. #341
    FLAC PURDooM's Avatar
    Jun 2005
    Anoka County, MN
    Quote Originally Posted by Viscouse
    I did find another odd issue. When I hit the zoom out button, it redrew the screen, and then infinately cycled the redraw, disabling all the buttons, cycling very fast, and rederning the program useless. This was while in RR. I couldn't even get out of RR. I had to end it from the task window.
    Weird. Was that RRs zoom out button or igmod's zoom out button?
    Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
    Unlimited Internet and gps tracking for $6 a month with boost mobile!
    Carputer 2: www.lmaocar.com
  2. #342
    Variable Bitrate Viscouse's Avatar
    Jul 2005
    Motor City
    igmod's. it only happened once, so it may be a freak occurance. If it happens again I'll let you know.
    You know you want to...Worklog
    Enjoying v1.0 since it's operational. Aaaawww yeah.
    Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
    Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
  3. #343
    Variable Bitrate lazy_g's Avatar
    May 2005
    Netherlands (Bergen (NH))
    does this actually work on the EU version of iguidance?
    If not is it going to be in the future?
    www.superchargedmiata.net - all about roadster lifestyle
  4. #344
    Jun 2005
    Anoka County, MN
    Quote Originally Posted by lazy_g
    No, very soon
  5. #345
    Jul 2005
    Motor City
    OK, I got another one. At certain times the map is in Pan mode. The way to exit PanMode is to click an "X" that's (I think) in the lower right corner. But all the spiffy buttons are (I think) covering the X so there is no way to exit PanMode without exiting IGM & restarting.
    Can the "X" be relocated perhaps up top, or in the middle of the right side? Or just tell me I'm an idiot because I missed something somewhere...
  6. #346
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    You can hit escape (or maybe x) on the keyboard to get outta that mode as well
  7. #347
    Jul 2005
    Motor City
    Thanks Sonic, that helps! Eventually though, ain't supposed to be a keyboard there.
    Hmmm, unless I have button to the osk on the map...
    EDIT: Esc works, X doesn't.
  8. #348
    Jul 2005
    Motor City
    OK, I found another one. Sorry...
    When trying to use the "Find Intersection" or whatever it's called, it freaked out.
    I hit the button, and the nice dialog box comes up. I type my first street, and it dutifully finds it. I say "Next", and it says "Loading Results".
    Then it hangs & never brings up the next dialog box which is supposed to ask me for the next street (or pick the appropriate intersecting street from the list).
    I tried it in IG proper, and it worked as expected.
    Next time I'm out I'll see if it happens in any other intersections, but I suspect it'll be the same.
  9. #349
    Jun 2005
    Anoka County, MN
    Progress update:
    Im wired on caffiene and just wrote 3 hours of code.
    Anyway, heres what the newest code ive added sense I can last remember:
    - GPS info sat picture works
    - Although load times aren't improved, memory used by bitmaps is at about 1/5 of what it used to be. Duplicate images only used once at a time are only loaded once. (headache to add)
    - "Resume Route" resumes the 2nd to last destination entered if a destination is already set. Ex: Driving home, you say "go to nearest gas station". Now you can hit "resume route" and it will continue on home.
    - The program is taking much more advantage of registry settings than it used too. Now, it sets iguidance's home position off screen before IG starts (no seeing map before program is running), it knows if mute is set and visually shows it and disables the click sound if mute is on, and it knows when fullscreen has been accidently invoked in iguidance and sends CTRL-F to fix it.
    - bunch of new toggles added to ini, including option to start maxamized (i was running it frontendless for a while and found it nessesary)
    - Focus is not stolen from children windows any longer (save recording as for example)
    I know, fix the POI they say, ill get there shortly.
  10. #350
    Jun 2002
    Virginia
    Great, PURDooM. I know we're all looking forward to the new version. I'm curious whether it's going to be optimized for RR or CF or whether it will work equally well with each.
  1. iGMod Beta 1 release
    By PURDooM in forum Other Cool Stuff
    Last Post: 12-28-2005, 11:17 PM
  2. Release 1.4 CENTRAFUSE BETA 2
    By veetid in forum Centrafuse
    Last Post: 08-02-2005, 11:20 AM
  3. Release CENTRAFUSE BETA 2 (1.3)
    Last Post: 08-01-2005, 04:13 AM
  4. RELEASE - FreeDrive 0.51 Beta
    By CdRsKuLL in forum FreeDrive
    Last Post: 04-20-2005, 05:03 AM
  5. RELEASE - FreeDrive 0.33 beta (D3 Frontend)
    Last Post: 02-18-2005, 04:08 PM
