Page 37 of 63 FirstFirst ... 272829303132333435363738394041424344454647 ... LastLast
Results 361 to 370 of 626
Thread: iGmod Beta 2 release
  1. #361
    Apr 2005
    Queens, New York
    Quote Originally Posted by Musashi450
    Hey so can someone point me in the direction on how to get igmod to look like this (the skin that says Action instead of Menu) I'm using the CFX skin for road runner but buttons go off the screen once custom is opened. Also I none of the gps buttons are working for me so if someone else has some experience with this problem it would be really appreciated (I've been searching for like an hour now). And PURDooM, I second whoever said that this is going to be a must have app. Great work
    You iguidance will look like that once PurDoom releases his igmod
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  2. #362
    Dec 2005
    ah, didn't realize that was on the new one he's pumping out. Well I'm looking foreward to it!
  3. #363
    Maximum Bitrate Civic03's Avatar
    Dec 2005
    Quote Originally Posted by PURDooM
    Preview 3:
    http://igmod.iamjeremy.com/iGmodPreview3.zip
    What works: Nearly everything
    What doesn't work:
    - patching 2.0NA (i cant execute it to see if it looks right) / 2.1.1NA (I apparently have the wrong version) / 2.1.2EU (lazy) with JIT's large next turn icons
    -Add/Remove/Edit favorites
    -Skinned gps info
    -Setting the programs images to be really high (like larger than 800x600) sometimes crashes. I think vb6 has limits to how much memory can be allocated to pictureboxes at once, ill figure out a solution.
    -scrolling up and down on the results screens seems a little slow, but not too bad
    -the OSK's in the points of interest screens screw up when pressing next/back from time to time (JIT has this bug with the standalone OSK)
    -previewing an item in the POI doesn't let you press "search again" to go right back to the results menu
    Readme file included.
    Im going to fix those last few bugs and test in my car over the course of the next week, but in the mean time I thought I would give the community something to play with.
    Does it matter where you install this software?
    PROGRESS 95%[//////////]Complete - Software configurations
    Current Task: Just adding on...
    Needed:wireless keyboard/mouse
    My Carputer Blog
    Car System Site
  4. #364
    Dec 2005
    I dont believe so, I'v installed mine in my road runner file and its working fine.
  5. #365
    Dec 2005
    Ok do I change the iguidance path in rrconfig to point to the path of iGmod? I'm not sure how to embed this with RR or even test it. Any help? I have it extrated and in the right places but not sure how to integrate it. BTW I put the path to iGmod. It's loading extremly slow and I'm not sure if this is normal behavior. It's sitting on the loading screen with the loading banner. It says loading images.
    My Carputer Blog
    Car System Site
  6. #366
    Dec 2005
    Make sure you are using the latest version (preview 3) and in rrconfig make sure to put the window name as --iGmod Reloaded-- . Yes the path goes to iGmod so my "GPS path" looks like C:\Program Files\Road Runner\IGMod\igmod.exe. Also make sure that your GPS mode in the config is set to external. You could also set it up as menu and then pick external from their. Hope this helps
  7. #367
    Dec 2005
    I'm using preview 3. It's still loading as we speak. It's been several minutes now. Even fed my dogs and talked on the phone is it's still loading!!
    All my settings match as you've stated above; with my path being different but to iGmod. I think maybe a reboot is in order!
    My Carputer Blog
    Car System Site
  8. #368
    Dec 2005
    Ok, no dice. Waited for over 20 minutes and it still didn't load although it was doing something because I saw it go from 1/20 tasks to 20/20 and then to starting iguidance but then nothing. I rebooted, did it again and still nothing.
    Oh well, not sure what is going on. I tried outside of RR and same issue.
    My Carputer Blog
    Car System Site
  9. #369
    Dec 2005
    Well don't ask me why but after I moved igmod directory under Road Runner/ it worked. Cool.
    My Carputer Blog
    Car System Site
  10. #370
    FLAC PURDooM's Avatar
    Jun 2005
    Anoka County, MN
    Glad to hear it worked out.
    Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
    Unlimited Internet and gps tracking for $6 a month with boost mobile!
    Carputer 2: www.lmaocar.com
  1. iGMod Beta 1 release
    By PURDooM in forum Other Cool Stuff
    Last Post: 12-28-2005, 11:17 PM
  2. Release 1.4 CENTRAFUSE BETA 2
    By veetid in forum Centrafuse
    Last Post: 08-02-2005, 11:20 AM
  3. Release CENTRAFUSE BETA 2 (1.3)
    Last Post: 08-01-2005, 04:13 AM
  4. RELEASE - FreeDrive 0.51 Beta
    By CdRsKuLL in forum FreeDrive
    Last Post: 04-20-2005, 05:03 AM
  5. RELEASE - FreeDrive 0.33 beta (D3 Frontend)
    Last Post: 02-18-2005, 04:08 PM
