Page 44 of 63 FirstFirst ... 343536373839404142434445464748495051525354 ... LastLast
Results 431 to 440 of 626
Thread: iGmod Beta 2 release
  1. #431
    Low Bitrate gothate's Avatar
    Oct 2004
    Hey does the spiffy new version work with the latest iGuidance? Or is that something I need to test?
  2. #432
    FLAC john1701's Avatar
    Mar 2004
    Fort Myers, Fl
    cant run it cause it says to run config tool first....
    I run config tool but get this error.
    Component 'TABCTL32.OCX' or one of its dependencies not correctly registered: a file is missing or invalid
    I will stick to beta2 for now. Which by the way is excellent!
    CAR:2001 Ford Crown Victoria
    PC: Acer EEE 900HA with Win7 with CF 2.0.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Screen:Xenarc 700TSV
    The Florida Meets Thread
  3. #433
    FLAC PURDooM's Avatar
    Jun 2005
    Anoka County, MN
    dependencies blow.
    Let me look up how to add tabctrl to peoples machines...
    Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
    Unlimited Internet and gps tracking for $6 a month with boost mobile!
    Carputer 2: www.lmaocar.com
  4. #434
    Jun 2005
    Anoka County, MN
    Quote Originally Posted by gothate
    I haven't yet made a diff file for 2.1.3 if thats what you are refering too.
  5. #435
    Jun 2005
    Anoka County, MN
    Alright, try this: I through together a crappy prototype installer for the external dependencies in iGmod. Tell me if it helps:
    http://igmod.iamjeremy.com/iGmod3/Components.zip
    Edit: this one doesn't work.
    You might need this:
    http://www.ascentive.com/support/new/libraryfiles.exe
    Extract it into the Config Tool folder with the folder name called "components" for best effect, but you can run the installer from anywhere without issue.
  6. #436
    Apr 2005
    Queens, New York
    Quote Originally Posted by john1701
    I had the same exact problem all i did was a search for tabctl32.ocx and DL it and put it in C:\Windows\system folder
    download it here:
    http://www.ascentive.com/support/new...b/TABCTL32.OCX
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  7. #437
    Mar 2004
    Fort Myers, Fl
    ok did all that, config now works, except now I run RR, hit gps, i get this, took dif shots...
    Now, if I close gps in RR, then open gps a second time it works. Also mention that when you close gps then exit RR back to windows igmod is still running in the background.
    hope this info helps you purdoom.
    also, igmod runs without NO problems by itself. Just in RR its having this prob.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
  8. #438
    Jun 2005
    Anoka County, MN
    The weird red menu is a debug menu you shouldn't be able to see. Ill take steps to make sure it doesn't show up at all.
    You sure you got the window name right in RR? Its not iGmod, its --iGmod Reloaded--.
  9. #439
    Dec 2005
    Hey Purdoom,
    So here's a quick cosmetic thing I've noticed. When I click dest and get to the menu and hit more, the text for record route, playback recording, and save location appear to be only partially on their corresponding buttons.
    Also I noticed when running the config that it should patch for 2.1.3 American (my version). I was successful in patching in the audio but not menu buttons so I'm going to go back again and manually patch them.
    After playing with the configs a bit, I'm getting run time error 53. It appears to be looking for "speedcutout.bmp" in the igmod folder. Possibly due to trying to enable optimizations?
  10. #440
    Jun 2005
    Anoka County, MN
    Quote Originally Posted by Musashi450
    Hey Purdoom,
    No, just my ignorance :P forgot some files.
    What optomizations is - I discovered that some of the menu entries (file, clear destination for example) have some kind of command number next to them in the reshacker. Using directions from marvin hlvac I found out i can make shortcut keys for these commands, like ctrl+w so you don't have to see the menu open. patch 2.1, 2.1.1 and 2.1.2 include those. But they cause crashing sometimes.
    Anyway, the link has been updated with the new files. http://igmod.iamjeremy.com/iGmod3/iGmod Preview 4.zip
  1. iGMod Beta 1 release
    By PURDooM in forum Other Cool Stuff
    Last Post: 12-28-2005, 10:17 PM
  2. Release 1.4 CENTRAFUSE BETA 2
    By veetid in forum Centrafuse
    Last Post: 08-02-2005, 10:20 AM
  3. Release CENTRAFUSE BETA 2 (1.3)
    Last Post: 08-01-2005, 03:13 AM
  4. RELEASE - FreeDrive 0.51 Beta
    By CdRsKuLL in forum FreeDrive
    Last Post: 04-20-2005, 04:03 AM
  5. RELEASE - FreeDrive 0.33 beta (D3 Frontend)
    Last Post: 02-18-2005, 03:08 PM
