I think a lot of people might begin using XPORT3, which is a com splitter than resolves the GPS Hibernation issues.
That said, some might be using the com splitter anyways, just for hibernation fix, and not to trully split ports...
hmm, so looks as if that would be are only option, I would be willing to use a com splitter, because that is the one function I really like from D3, the auto zoom, because when your on the highway it's much better to be a ways off.
肚子笑痛了
S60 Install
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
Feel free to mess with this:
http://www.sterlingv.com/users/purdoom/beta21d.zip
Im not sure, it feels a tad bit sluggish on processing some of the commands from buttons on the map, but its the most stable thing I have right now.
(Gotta get this out there so I can spend the rest of the day studying for classes)
Just so everyone knows, the largest bug is a lack of ability to add / edit favorites.
Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
Unlimited Internet and gps tracking for $6 a month with boost mobile!
Carputer 2: www.lmaocar.com
Originally Posted by PURDooM
if I click on menu and then points of interest, and then pick a category, it gives me a pretty extensive lisf of items. scrolling down through this list to try to find a specific thing I'm looking for is almost impossible. I think it would be alot better if I could search that list, as iguidance does by default w/o gmod.
PURDooM,
I downloaded the latest version you posted. It still hangs when I go to restaurants in POI. I mention this only because you stated in an earlier post that you had resolved this issue.
Still crashes when i try and click on anything in Main Menu
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
I assumed i did... how does it hang? Did it hang on beta version one as well?Originally Posted by kbreeden
I swear... im really close to just recoding the whole programIn fact... I think ill start that now. It wouldnt be hard (I can use alot of the old code/concepts, should only take 4 days or so)
And this time ill write the code so it doesnt look like crap. And make it open source.
please ad a way to search the POI in this new igmod that ur coding up. Thanks!
When I click on the restaurants button it just stops responding. No other buttons work. A couple of times when trying to recover I have noticed that the IGuidance POI menu screen is loaded behind the IGMod POI screen.
I never used Beta 1 so I don't know if it had the same issue.
I'm using IGMOd in CF.
I experienced this as well.Originally Posted by kbreeden
