Page 53 of 63 FirstFirst ... 34344454647484950515253545556575859606162 ... LastLast
Results 521 to 530 of 626
Thread: iGmod Beta 2 release
  1. #521
    FLAC PURDooM's Avatar
    Jun 2005
    Anoka County, MN
    Quote Originally Posted by gothate
    Yeah no kidding!
    Are there any, uh, plans to make igmod work with the 2.1.3 or do I have to do the skinbedder stuff and manually patch it? I'm so trying to avoid that...
    Yea, I just have to mess with reshacker on it to make a 2.1.3 patch, should be half an hour of work or so. Its just annoying because all the locations of the resources are different in 2.1.3 so I cant just import all the 2.1.2 resources into 2.1.3
    Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
    Unlimited Internet and gps tracking for $6 a month with boost mobile!
    Carputer 2: www.lmaocar.com
  2. #522
    Dec 2004
    Error with igmod
    I am getting an error, Run-time error '75' Path/File access error when I try and launch igmod after all the config stuff. I have installed all the library files (including the files from Ascentive), ran the config tool (but I do get a error when it trys to register msflxgrd.ocx, says it is not an executable, or there is no helper file associated with this type of file). Has anyone had this problem? I am running windows 2000 and preview 4.
    I also just for yacks tried it on an XP system, and it works flawlessly. Has anyone used 2000 successfully?
    Sweet Program, I just wish I could get it to work!
    Thanks for any input
    GUDY
  3. #523
    Jun 2005
    Anoka County, MN
    I put out a bad flxgrd file, I have in my working copy a correct one. You only need flxgrd for the skin editor anyway.
    Not sure on what the error 75 could be caused by...
    Everyone else: School ensues, I have 2 tests tommorow, thats why I am behind on updates. In the mean time, check out the web page: http://igmod.iamjeremy.com/iGmod3/website/index.html
  4. #524
    Dec 2005
    come on, man. where's your priorities???
    good luck on the tests...
  5. #525
    Dec 2004
    hmmmm, I am working on the error, it looks like it is missing some vb files, I am going to install vb6 and see if that works. If not, I might be able to run it in a debugger and see if it is still missing a dependent file. I will let you know what I find.
    GUDY
  6. #526
    Dec 2004
    Ok, I am a dumbass, wasted well over 3 hours trying to figure this out. So simple, I burned all the files onto a cd first, then onto the computer. Well, when you do that, it makes all the files READ ONLY.
    Works great now! Thanks for the help, and hope you did ok on your tests
    GUDY
  7. #527
    Constant Bitrate noreason's Avatar
    Jan 2006
    Texas!
    nice program and nice choice of music
    twiztid
  8. #528
    Jan 2006
    Finland
    Hey,
    For some reason, I receive only a web page with letter H when I try to download IGMOD or access the site?
  9. #529
    Nov 2004
    St Louis
    Quote Originally Posted by PURDooM
    Nickfury: Thats good to hear!
    b8bboi: Hmm, ill overhaul the debuging feature to log basically every command that iGmod does with timestamps and get you a special debug version sometime in the next few days. We'll get that figured out.
    I'm a little late to the game, but I can't get iguidancemod.exe to embed in igmod reloaded. I checked the debug.txt and everything is O.K. except I get a "Calibratespeedview FAILED" then "Frm1.timer1 says there is no iguidance running, so we are restarting it."
    This happens over and over till I kill IGMod: I can see IGuidancemod start, IGMOD closes the nagscreen OK, but the map flashes onscreen then disappears, IGMod flashes a couple times and the nagscreen flashes onscreen again.
    This doesn't happen on my development system or my MII10000, just the tablet, first time its failed me. I've tried preview 3 and 4 and both act the same way.
    OBTW, I'm trying to run it standalone - once that works then I'll worry about CFX integration.
  10. #530
    ITL
    ITL is offline
    Maximum Bitrate ITL's Avatar
    Jul 2004
    Atlanta, GA
    Quote Originally Posted by GizmoQ
    I got that, too. A reboot fixed it for me...The only thing I can't deal with is the lag on the OSK...iG preview3 (or maybe v2, I can't remember) wasn't as bad as this p4.
    CarPC #3: 99% Complete
    Pentium M 1.7Ghz, 1GB DDR2 RAM
    DVD/CD-RW installed in dash below monitor
    OEM LCD relocated for 7" Touchscreen
    Wi-Fi, GPS, PS2 controllers...
    500+ full albums
    4,000+ video games
    music videos, movies, & more!
    old carPC
  1. iGMod Beta 1 release
    By PURDooM in forum Other Cool Stuff
    Last Post: 12-28-2005, 10:17 PM
  2. Release 1.4 CENTRAFUSE BETA 2
    By veetid in forum Centrafuse
    Last Post: 08-02-2005, 10:20 AM
  3. Release CENTRAFUSE BETA 2 (1.3)
    Last Post: 08-01-2005, 03:13 AM
  4. RELEASE - FreeDrive 0.51 Beta
    By CdRsKuLL in forum FreeDrive
    Last Post: 04-20-2005, 04:03 AM
  5. RELEASE - FreeDrive 0.33 beta (D3 Frontend)
    Last Post: 02-18-2005, 03:08 PM
