Page 58 of 63 FirstFirst ... 848495051525354555657585960616263 LastLast
Results 571 to 580 of 626
Thread: iGmod Beta 2 release
  1. #571
    ITL
    ITL is offline
    Maximum Bitrate ITL's Avatar
    Jul 2004
    Atlanta, GA
    Quote Originally Posted by PURDooM
    Hmm... I know I did it to my car's version (300 mhz doesnt cut it for fades) but I don't know why your copy isn't working.
    I hope I didn't code this in after the last release...
    Man, it would be great if that weren't hard-coded. Anyways, what is TABCTL32.OCX? When trying to run the config tool, I get an error about this file: "Component 'TABCTL32.OCX' or one of its dependencies not correctly registered: a file is missing or invalid.
    Is there any documentation that lists all options/switches for the irunner.ini?
    CarPC #3: 99% Complete
    Pentium M 1.7Ghz, 1GB DDR2 RAM
    DVD/CD-RW installed in dash below monitor
    OEM LCD relocated for 7" Touchscreen
    Wi-Fi, GPS, PS2 controllers...
    500+ full albums
    4,000+ video games
    music videos, movies, & more!
    old carPC
  2. #572
    FLAC PURDooM's Avatar
    Jun 2005
    Anoka County, MN
    Quote Originally Posted by ITL
    tabctl32 is the activex control for tabs in visual basic projects. Check this page:
    http://www.ascentive.com/support/new...e=TABCTL32.OCX
    Their ascentive library installer seems to fix all them problems I didn't forsee in program distribution. Its commercialware, so I think I have my own solution that will be spread around in the next release.
    The runner.ini looks for toggle words (true/false):
    _____________________________
    donotkillnag [depreciated]
    useigmodnag [not recently tested]
    frodo [legacy from beta 2, unimplemented]
    standalone [either this one or the next one is ignored, don't remember which one off hand][
    nostandalone
    antialiasing
    nofade
    semitransparent (not in current release... I think?)
    startmaxamized
    autorecord (not in current release)
    The following keywords also take some kind of paramater:
    screenwidth
    gpsoption
    screenheight
    skin
    skinpath
    modeoffscreensetting
    modeoffscreenratio
    modeoffscreenrnudge
    igoptions
    And finally, 'APPLYDIFF (diff file)' applies a filter to a skin file (for example to remove all POI buttons or something)
    Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
    Unlimited Internet and gps tracking for $6 a month with boost mobile!
    Carputer 2: www.lmaocar.com
  3. #573
    Variable Bitrate Viscouse's Avatar
    Jul 2005
    Motor City
    0. The thing in the upper right is the "off screen icons" defined from the last tab in the configuration utility.
    OK, I can dig that. I found the option to disable it, but for some reason, the options I pick don't stick.
    Shut down RR, igmod & IG, launch the config, make changes in the last tab, hit save, then exit. Fire up RR & igmod and it's like nothing happened. If I repeat, the optios I chose haven't been picked.
    Any idea why config settings aren't sticking?
    You know you want to...Worklog
    Enjoying v1.0 since it's operational. Aaaawww yeah.
    Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
    Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
  4. #574
    Jun 2005
    Anoka County, MN
    Quote Originally Posted by Viscouse
    It should save... it saves to the runner.ini in the directory just prior to the config tool so if iGmod is at c:\igmod\ and the config is at c:\igmod\config tool\ then c:\igmod\config tool\config.exe saves to c:\igmod\runner.ini.
    It doesn't load settings because I didn't feel like coding that in (lazy bum )
  5. #575
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    I encourage you to kjeep up work on the application. There are tons of people who use and it very useful.
    It just needs to be a bit more stable. and the navigation screen needs a little bit of work.
    Thanks again for all your work on this
  6. #576
    kuo
    kuo is offline
    Variable Bitrate kuo's Avatar
    Jun 2003
    Greensboro, NC
    if igmod basically mirrored what the normal iguidance menus did this app would be perfect. everything about the app is just outstanding. great work purdoom.
    my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
    wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
    company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
  7. #577
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    I agree. The same menus with just bigger buttons and most importantly a big OSK.
    Great job thus far!
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
  8. #578
    Jul 2005
    Motor City
    No sweat dude. I would call you anything but lazy!
    So I understand the concept now. I verified that chosen options in the config stick in runner.ini.
    But, now I have this line in the .ini which I wanted to be "don't show nav" and it says:
    modeoffscreensetting 0
    I still get that nav window in all RR screens.
    Any more ideas? Am I the only one with this?
    And just in case you think I'm a nag, I do notice a great improvement from Preview 3 to 4...much more stable. That's what I was after!
  9. #579
    Jun 2005
    Anoka County, MN
    I thought I tested this enough, but I guess it needs a 2nd look at. what you did should have worked
    And I could use the nagging. However I expect huge strides the next week or so (spring break, and I only work 17 hours/3 days of the week so lots of free time)
  10. #580
    Fusion Brain Creator
    Mar 2005
    I can take a screenshot later, but my GPS info isn't displaying. Any tips?
  1. iGMod Beta 1 release
    By PURDooM in forum Other Cool Stuff
    Last Post: 12-28-2005, 11:17 PM
  2. Release 1.4 CENTRAFUSE BETA 2
    By veetid in forum Centrafuse
    Last Post: 08-02-2005, 11:20 AM
  3. Release CENTRAFUSE BETA 2 (1.3)
    Last Post: 08-01-2005, 04:13 AM
  4. RELEASE - FreeDrive 0.51 Beta
    By CdRsKuLL in forum FreeDrive
    Last Post: 04-20-2005, 05:03 AM
  5. RELEASE - FreeDrive 0.33 beta (D3 Frontend)
    Last Post: 02-18-2005, 04:08 PM
