Good to see you back, PURDooM.![]()
In RR, it should be the next turn indicator (disablable in the config), but a bug with Igmod and RR not cooperating together is causing the next turn indicator to be broken. Turn it off if you are using RR in the config tool by setting off screen icons to disabled.
Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
Unlimited Internet and gps tracking for $6 a month with boost mobile!
Carputer 2: www.lmaocar.com
You know you want to...Worklog
Enjoying v1.0 since it's operational. Aaaawww yeah.
Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
Why thank you. All my class finals will be done on thurs!![]()
With me figuring out how to get super cheap internet in a carputer, I am planing on starting a GNav application soon after I finish some loose ends in iGmod. It will be a iGuidance style app that uses Google Maps for the map data and the routing/rerouting.![]()
Originally Posted by camsgs3
Yup I get the same problem even if I turn "no out of program nav icons" off, at firts the box is black, then white and then it goes away.
I tryed every other possible config for the route icons but there is always the same resoult.
Thanatos.
Yeah, I don't really want the maps as much as I want the map tiles (build a cache full of RLE images) and the routing data that can be provided by google. The end result will use google maps data, but the interface will be new.Originally Posted by RPM_VR4
So PuRDooM any idea what is going on with the route icons?
Thanatos.
Nope.Originally Posted by thanatos106
Ive tried searching this thread for this problem, but have not found it yet. So, I think that this may be a new bug in igmod.
Im trying to embed igmod in RoadRunner. The embedding works but with a slight problem as described below.
Versions: RR version dated 5-02-06
igmod: beta 2 preview 4
Iguidance: 2.1.3
The first pic is Igmod running in standalone. It works fine, no problems. All the menus work correctly as expected.
The second pic is igmod running embedded in roadrunner. The app starts fine but then a window titled "WndRecieveiGmod" opens immediately with some buttons on it. This window can be closed and the igmod runs embedded just fine. Just wondering why this window opens in the first place while running embedded. I have the apps windows name in RR as "iGmod".
I believe this to be a bug.
Civiputer: Dont have one anymore, but here is what is used to be!
the problem is you arent using the full window name for the gps window in road runner; try using the phrase iGmod Reloaded rather than just igmod.
