Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 52
Thread: Internet dection
  1. #31
    Maximum Bitrate skippy76's Avatar
    Mar 2004
    Cambridge, MA, USA
    Ok. So I'll look to fix that in RR.
    06 Volvo XC90
    Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
    Car PC downloads: http://carpc.harteveldt.com/
  2. #32
    May 2005
    Vienna, VA
    Great. Thanks.
    But in the mean time, could you add "offline" support to your app while we're waiting for the next release of RR?
  3. #33
    FLAC -zip-'s Avatar
    Ontario/Canada
    Quote Originally Posted by b8bboi
    Great. Thanks.
    b8bboi, can you share how you auto downloaded the weather info? I really would like to be able to do this.
    Sound Stage
    Eclipse|MTX|Infinity
  4. #34
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    just downloaded the net detect program. Works PERFECT for what i need it to do (simple application running) Thanks!
  5. #35
    Maximum Bitrate cadence117's Avatar
    Feb 2004
    Charlotte, NC
    Wow incredible, wow, awesome, thankyou
    The world has been waiting for this app
    mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
    Total = $746....Carputer = Priceless
  6. #36
    May 2005
    Vienna, VA
    Quote Originally Posted by -zip-
    Sure. The code is in my car pc. I'll attach it sometimes later.
    It's pretty simple. It's just a VBScript that makes HTTP requests to weather.com and traffic.com. The weather one automatically uses the location setting inside your RR.ini. The traffic one, you just need to give it the correct URL.
  7. #37
    May 2005
    Vienna, VA
    Use UpdateWeather.vbs to update weather. If you don't have XMLHTTP installed on your PC, you can download it from microsoft.com.
    User GetHTML.vbs to update any web site you want. I set it to grab content from a RSS feed from traffic.com. It takes two parameter. The first is the URL of the web site. The second is where you want to save your file locally.
    See UpdateWebsites.bat for sample usage of those 2 scripts.
    After you edit it to include the web sites you want to download automatically, just put a path to UpdateWebsites.bat in skippy's Net Detection.
    Attached Files Attached Files
  8. #38
    May 2005
    Vienna, VA
    There's some extra code in the script I posted above that you won't need. Download this one instead. Remember to edit the path in UpdateWebsites.bat so that it points to the correct locations for UpdateWeather.vbs and GetHTML.vbs.
  9. #39
    Variable Bitrate 0okami's Avatar
    Feb 2006
    USA
    Quote Originally Posted by skippy76
    I'm writing in VB 6. I was just starting to look at the FTP side, but the calling an app sounds a great idea. I shall look into that now!
    This sounds good to me too! i could use something like this.
    ~0okami.Digital
  10. #40
    FLAC -zip-'s Avatar
    Ontario/Canada
    Well I did it .
    After looking at b8bboi's script it did not match the integration into RoadRunner that I wanted. So I started looking at the xml feed that is used. I copied the same format and using an AutoIT script to save it as myweather.xml in the RoadRunner directory and compiled it into a .exe for net-detect to start it. Works perfect, updated weather in RoadRunner on the fly.
    Woot!
    Sound Stage
  1. Instructions on getting FREE wireless internet from T-Mobile using GPRS
    By bankingdom in forum Wireless Communications
    Last Post: 08-16-2011, 03:37 PM
  2. Auto security uses wireless internet
    By Romeo in forum Wireless Communications
    Last Post: 05-07-2005, 05:42 AM
  3. how do i get the basic internet
    By carchrism5 in forum Wireless Communications
    Last Post: 03-15-2005, 12:24 AM
  4. Cable TV over the internet
    By DrBuzzo in forum Wireless Communications
    Last Post: 12-06-2004, 05:57 PM
