Page 15 of 21 FirstFirst ... 56789101112131415161718192021 LastLast
Results 141 to 150 of 208
Thread: GaroNav 1.0 beta 1 Released
  1. #141
    Variable Bitrate nameeri's Avatar
    Mar 2006
    SoCal
    That might be a problem with the gps skin that you are using with RR. Try adjusting the coordinates for the "AXX" line. You should have it go from the top left, all the way down to where its just above the audio control buttons.
    Civiputer: Dont have one anymore, but here is what is used to be!
  2. #142
    Constant Bitrate teo256's Avatar
    Mar 2006
    Fossombrone (PU), Italy
    This is my skin's setting for nav:
    /[Window]
    /, A, x, y, w, h, color;RGB
    A01,200,42,600,514,192,192,192
    /[/window]
    So, if I do not wrong, it's ok.
    In RR Config, how do you set the GPS program? MapMonkey or MapPoint or External??
    Software [|||||||||-]
    My Own RR Skin [|||-------]
    8" LCD TS 1024 x 768 - Epia M10000 - M2 ATX - 512 Mb - 40 Gb - Creative Sound Blaster Audigy 2 ZS Video Editor - Sitecom BT Dongle - GPS BT-77
    RoadRunner - Destinator 6 - Waiting for RRMobile
  3. #143
    FLAC mauri's Avatar
    Jan 2004
    In RR config utility:
    GPS: EXTERNAL
    GPS Path:C:\Programmi\Garonav\GaroNav.exe (use your directory)
    GPS Window name:GaroNav
    Mauri
  4. #144
    Mar 2006
    Thanks very much, now it's ok.
    Just a note: i noticed that GaroNav has a slower startup than MapMonkey.
  5. #145
    May 2005
    Vienna, VA
    GaroNav also makes my CPU go 100%. I think that's more because of my setup though since it works OK on my other computer.
  6. #146
    FLAC mauri's Avatar
    Jan 2004
    GN it's write in .NET v2, hight use of CPU in the startup,but language very good respect to VB6 for developments....
    The initial load of GN it's slow if launch the full skin (settable in the "Settings" of GN skin).
    Inevitable this !
    Edit:Use the "Hibernate" mode, ad solve the initial problem of loading the full skin!
    Mauri
  7. #147
    Mar 2006
    How to use the Hibernate mode??
    About the full skin loading....i've to check in my carpc...i don't remember.
  8. #148
    FLAC mauri's Avatar
    Jan 2004
    Set in your System the "Suspension" mode:
    With Panel of control,if you click in the on/off PC button,set "Suspension" mode.
    Also active it.
    Mauri
  9. #149
    Mar 2006
    I have activated it, but before to Hibernate the pc, appears a windows that asks to me if i want to close the BT Audio-gateway. If i do not press OK, the pc will not hibernate. There is a way to disable this message??
  10. #150
    Mar 2006
    ok, i've fixed the issue with the BT message, but i have a "stupid" question: why to use the standby? Isn't the same of the shut-down??
  1. Garo's Extra POI Plugin 1.0 beta 1
    By garo in forum Map Monkey
    Last Post: 01-18-2007, 12:32 PM
  2. Problems installing Girlfriend 1.0...
    By gospeed.racer in forum Off Topic
    Last Post: 10-18-2005, 05:17 PM
  3. Replies: 4
    Last Post: 08-12-2005, 09:51 AM
  4. Remote Playlist Manager for Frodoplayer - 1.0 Beta 1
    By PatO in forum Software & Software Development
    Last Post: 03-17-2005, 01:58 AM
  5. Blackwind's keypad plugin v2.0 beta released
    By Blackwind in forum Software & Software Development
    Last Post: 02-11-2001, 03:54 AM
