Page 7 of 21 FirstFirst 1234567891011121314151617 ... LastLast
Results 61 to 70 of 208
Thread: GaroNav 1.0 beta 1 Released
  1. #61
    Variable Bitrate garo's Avatar
    Jan 2005
    Milan, Italy
    Quote Originally Posted by RoyN
    no problem it is actually the same process for GaroNav so its ok to leave in this thread...
    I was just a bit since this is just a lone thread in a pretty much hidden forum, whereas there is a dedicated FD forum which I thought would be much more obvious a place to ask... I was a bit taken a back that you got to the trouble of fidning THIS thread, and didnt find the FD forum... glad I could help, though
    Yeah I know... Do you know who I have to ask for a subforum?
  2. #62
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Frodo...
    I'd wait a bit though... when you get the next version, post a notice in the main software secgion (took me a while to notice this post here!), and then when you get more questions/ppl you can ask for your own forum...
    just my suggestion
    Roy
    2005 Range Rover 4.4
  3. #63
    Aug 2004
    Garo,
    I like it! My thoughts: It seems like the menu buttons are a bit hard to push, or they're a bit slow. i push it and nothing happens, I wait, I push again and it goes right away. Did I miss the first push? Or was it just thinking about it that whole time? this happened over and over so im not sure if something can be done to make the buttons a bit more 'positive'.
    I wish there was media controls because I usually just leave my screen on nav, its nice to have volume and track controls there.
    I had to change things around to get my gps on com3. I couldnt find anything files or anywhere I could set it to my standard, higher port. I use Xport so I have gps ports on 4 through 8, for the sole purpose of testing apps like this.
    The speed is incredibly off on my setup. It works perfectly on mapmonkey, freedrive, and with the gps speedo proggys but on GN it shows erratic numbers, I was going 4560mph at one point today.
    thats all the gripes Ive got. I like the simple interface, and the address input is much nicer, although lacking the 'show, navigate, save' options.
    thanks!
  4. #64
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    Ok had a few days to try this, good pints first.......
    The thing works fine for me not one crash or hiccup (ukmap)
    Now the annoying....
    Some 'dialogs' are the original destinator sdk dialogs and they are too small to work with on a small touchscreen (ie gps setup)
    'trying to reconnect gps' stays on screen making it a pain to test indoors!
    I live in 'york' but the search throws up a whole long list because of the search hitting the text in brackets after the actual text, IE
    Acomb(North Yorkshire)
    Tollerton(York)
    YORK(North Yorkshire)
    Either it needs to stop 'hitting' the bracketed text, or, sort the list so its weighted with the more probable hit at the top, tricky but not that hard.
    Now the BAD............
    My home address is missing! My local streets are missing!
    Its not your fault its the sdk I think, it happens when you search city,street,number but they appear (on other software IIRC) if you search street, city.
    Its really hard to impress friends when you cant even get it to show you the way home....
    Other than that 5 stars for a damn good beta.
    I have not yet had the time to try it in frodo, hope it embeds well, or at least gets a launcher.(please please not the mapmonkey launcher - my touchscreen wont work where the 'hide' button is placed!)
    In summary, youve done damn good and I like it.
  5. #65
    Jan 2005
    Milan, Italy
    This happens because your pc may be to slow to load skins in real time (it's normal ). Try to select "load whole skin at the beginning" in the option screen. The first loading may be slower but the program should be much faster.
    I won't put media control because GN should be embedded in frontends like RoadRunner that are able to do such a thing.
    I use Destinator dialog for this, so wait untile PN will work to see if this is fixed.
    Very strange since I use what I find in NMEA/Sirf data..! I don't calc speed, it is just given by the GPS.
    They'll come
  6. #66
    Jan 2005
    Milan, Italy
    Yeah I know, I probably change them in the future.
    I'll make this an option.
    Tollerton(York)
    I also noticed this. I'll implement the second method.
    VERY strange... This didn't ever happen! Has someone the same problem?
    São Paulo, Brazil
    Come on garo, what do you have in store for us? any news on the PN stuff? did you get any far with it? (did you see my post in the PN SDK thread?)
    Do you see any advantages for us? I still dont see streetnames in the 3d view, which would be cool...do you think it could be added (I think ninja monkey experimented and was able to get some names on birdseye view, but birdseye in D3 looked so crappy)
    Roy
  8. #68
    sim
    sim is offline
    Low Bitrate sim's Avatar
    Jan 2005
    Gloucerstershire UK
    Quote Originally Posted by Vinister
    Garo,
    thanks!
    I also have this, is it an internationl variation or soething to do with MPH vs KMH
    Also ETA & ETR is inaccurate as is Distance Remaining
    PC Chips 1500,512mb ddr,no case yet, LinITX 7" touchscreen,300w inverter,RoadRunner FreeDrive,BU303 gps mouse.
  9. #69
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    I didnt.......
    But thats not important what is and the reason for this is why is it called PN ?
  10. #70
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    top man.
    I did it that way once for a search in a video tape library to part match film titles and customer names, took about 3 days to do in the end, day one I had it working but it took about 15 mins to search, by day three it was using indexs and down to 20 seconds to do about 5000 records.
    May not sound impressive but that was on an amiga 500 on dual floppys in basic.
  1. Garo's Extra POI Plugin 1.0 beta 1
    By garo in forum Map Monkey
    Last Post: 01-18-2007, 01:32 PM
  2. Problems installing Girlfriend 1.0...
    By gospeed.racer in forum Off Topic
    Last Post: 10-18-2005, 06:17 PM
  3. Replies: 4
    Last Post: 08-12-2005, 10:51 AM
  4. Remote Playlist Manager for Frodoplayer - 1.0 Beta 1
    By PatO in forum Software & Software Development
    Last Post: 03-17-2005, 02:58 AM
  5. Blackwind's keypad plugin v2.0 beta released
    By Blackwind in forum Software & Software Development
    Last Post: 02-11-2001, 04:54 AM
