View Poll Results: Which version runs better on your carpc?
Voters
6. You may not vote on this poll
  • The Swf in the 2nd post
    0 0%
  • The Exe of the Swf in the 3rd post
    2 33.33%
  • The New Exe in the 4th post
    4 66.67%
Multiple Choice Poll.
Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 66
Thread: Release: Draw 1.0 aka Paper and Pencil
  1. #41
    Raw Wave lostreception's Avatar
    NY
    Quote Originally Posted by ZeroG
    Im not sure what the skin file is for but can if be edit like persay a skin so that I can put a small autohide media controller to pause and mute.
    by the way excellent app especially seeing how I rarely post unless its something excepional so good job on your part and on Chuck on starting this.
    the skin is editable just like a rr skin
    just not as slick yet
    the skin and editing like rr only applied to my most recent post
    as for media buttons do you mean like send keys to rr like play/pause and mute
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
  2. #42
    NY
    ah after reading on i think i got what your saying you want to be able to clip the program? and have it transparent in an area to see thru it to your media control?
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  3. #43
    Newbie ZeroG's Avatar
    Jan 2006
    yeah sort of..
    that would work fine too
    but in my GPS skin for my Streets and Trips when I click a button and it opens an additional part to the skin which covers the very bottom part of the screen and gives me functions such as play pause stop and volume.
    And Ill click it again to make it dissappear
    but since you say its just like a regular rr skin that should be easy to implement right?
  4. #44
    NY
    yeah sort of..
    the skinning part is just like rr and it can send commands to rr but to make a play pause stop popup seems like overkill you could just as easily embed this slightly above the current controls as in lsx or ls3.0 and still maintain the functions of music control
    this app is mainly made for full screen and an occasionaly jot down of something when paper is not handy having this screen up for more than a min or so doesnt seems too likely its not a main page like gps and or phoco . its doable im working on popups now ill see if i have room its pretty cramped already
    even with the popups
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  5. #45
    NY
    UPDATE 1-23-06
    Added clicksound
    oddly enough it works sporatically on my machine let me know how it performs on all of yours
    Added popup menu for line size
    Redesigned Skin file and added support to skin all buttons on front of app
    skinned the rest of the app
    no more ugly winblows command buttons
    NOTE skin is greater than 200 kb now and i cant attach it in the forums
    i need a better ghetto "free" host than the one i have now
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  6. #46
    NY
    Link to download new version
    its on my crappy free host sorry about the popups
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  7. #47
    Aug 2005
    I've tried the exe and swf versions and both bring up the main close menu for RR when you hit the close button. The exe version doesn't display the song being played at the top and the swf doesn't fit correctly, doesn't seem yo be 800x600 more like 800x480?
    The size problem is odd as I have 800x600 in the general.ini and I thought that stretched all skins
  8. #48
    NY
    Quote Originally Posted by Silentbob343
    swf doesnt even do that even it is done thru a .skin file that is bundles with the swf version
    The exe version doesn't display the song being played but it can pm me and i can add it but i think it will probably lag pretty bad
    i never had pictured this app for long term use or picasso drawings just a quick jot here or there. its pretty cpu intensize because its flash theres a possibility i could make an app in vb that does the same thing but I think this will probably due for now if you need anything else let me know
    how are you entering the exe in what screen it shouldnt open the close dialog imediatly as it sends a "cancel" command to RR unless you hit it more than once it shouldnt bring that screen up
    if you could map out where u have it opening from that would help
    mainmenu>launch>draw for example
    you will need to change some parameters in draw.ini
    depending on the version
    for ex
    programsize, 800, 600 , 0 , 0
    or
    ShowWidth=800
    ShowHeight=600
    XPosition=0
    YPosition=0
    if your using any of the other versions they should stretch to fit
    if you can make a screen shot that would help alot
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  9. #49
    Aug 2005
    For the SWF version I put all the .jpegs and .skins in the BMV skin folder. With either version I enter draw by simply hitting the XM/Sat radio button. I only hit the close button once.
    Code:
    SWF:
    B06,11,305,339,106,"LOAD;draw.skin"
    and for the exe version I linked back to a folder
    EXE:
    B06,11,305,339,106,"RUN;D:\Documents and Settings\MASTER\Desktop\Draw10EXE\draw.exe","Draw"
  10. #50
    NY
    as for the skin file take a look at this line in it
    /, F, x, y, w, h, Movie name
    F01,0,60,800,420,"draw.swf"
    change that 420 to 600 that will solve the size issue
    i overlooked that the flash projector talks the same way that RR does when sending a command so sending an exit command for the flash player executes an exit on RR too try this swf
    i changed it to a cancel command somewhere with all the different versions i overlooked this probably didnt save it after i changed it
    Both changes are included in this repack
    Attached Files Attached Files
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  1. Attention Newbies! A FAQ to the FAQs
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-16-2006, 12:17 AM
  2. Replies: 9
    Last Post: 06-08-2006, 06:15 PM
  3. Replies: 19
    Last Post: 10-27-2005, 12:53 AM
  4. Just for laught: Computer and Car
    By MatrixPC in forum Off Topic
    Last Post: 01-05-2005, 10:25 PM
  5. Real Time Car tracking now working!
    By Magpie in forum GPS
    Last Post: 10-27-2004, 05:08 AM
