View Poll Results: Which version runs better on your carpc?
Voters
6. You may not vote on this poll
  • The Swf in the 2nd post
    0 0%
  • The Exe of the Swf in the 3rd post
    2 33.33%
  • The New Exe in the 4th post
    4 66.67%
Multiple Choice Poll.
Page 1 of 7 1234567 LastLast
Results 1 to 10 of 66
Thread: Release: Draw 1.0 aka Paper and Pencil
    Raw Wave lostreception's Avatar
    NY
    Released: Draw 1.0
    Special thanks to Chuck for creating the default buttons and of course the original idea
    UPDATE 1-23-2006
    New Skin
    Newest Version: DOWNLOAD LINK
    See 4th post below as well for a screen shot
    [/SIZE]
    UPDATE 1-16-2006
    Fixed save issue and uploaded swf version
    exe version is also updated!!!!
    Currently this version Supports All frontends via the .exe version
    I will need some feedback from other frontend users as to the size (pixelwise) to make the exe for those frontends
    when i have that completed this thread i will request be moved to a different location on the forum
    Donations are Welcome
    Special Thanks to those who have donated
    Donations:
    Code:
    Chuck 30.00
    Install:
    Unzip files to your skins directory
    and call it from a button you define in RR
    Included is draw.skin a default skin to place the program in
    (see screenshot below)
    I made this with skinnability in mind
    All graphics seen are customizable simply by changing the .jpgs
    Colors of the text are also configurable from the file colors.txt included in zip as well
    There are 2 zip files included below
    (one currently ill add the second)
    Draw1.0.zip is the flash version that is alreaddy embed in RR with a .skin file
    Draw1.0exe.zip is the standalone version but still relies on the external jpgs and colors.txt
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
    NY
    UPDATED 4-02-2007
    Roadrunner zip Including .skin files
    .Removed link
    now hosted @ http://lostreception.carpcnet.com
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
    NY
    Here is the Exe Version in a zip file follow the same instructions as above just extract and run
    UPDATED 4-02-2007
    removed file
    EXE Version Wrapper written
    pretty self explanitory
    draw.exe has draw.ini and draw.swf as depenancies
    EXTRACT ALL FILES TO THE SAME DIRECTORY
    Draw.ini is only really neccisarry is running standalone
    but can be useful to presize window to your prefered size
    RR and CF i belive already do this on startup
    I'll need some feedback on this as it is my 1st program so to say written in VB
    Thanks for your help
    Big thanks to guino as without his source for the SDK I'd be totally lost
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
    NY
    EXE version but skinnable
    DOWNLOAD
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    Hi.
    Thanks for the very nice application.
    There is one problem though when this is embeded in RR. I'm using the .exe file which is embeded in an empty RR skin (no buttons). Once the app. is called, it embeds perfectly into the RR skin. The problem is that when pressing the "Close" button the application closes but the empty RR skin is still there and there is no way to close it and return to a previous screen. I know I can add an exit button on the RR skin but that would make the available screen area smaller. Is there anyway to make the application send an "exit" code to the RR skin so the application and the RR screen close and return to the previous screen or the main menu of RR?
    Thanks for all your hard work and patience.
    Oh. and one other thing. Can the Preview text be made so we can change the color ?
    The road is long but we are getting there.
    NY
    Quote Originally Posted by tolisn
    Hi.
    use the exe but change the first line in colors.txt
    runningasexe=false instead of true
    that will make it send an exit command
    i missed the preview sorry will update downloads and document the 1st post when i make the change
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
    Dec 2003
    Greece
    I tried what you suggested. When I know press the “Close” button nothing happens. Neither the application nor the skin close.
    NY
    looks like if u want to run the exe you will need to run it with a close button
    the swf button executed the exit command with no problem
    seems because flash itself is not running the flash (the flashprojector is) the command doesnt get sent
    maybe someone witha little more experience with flash and rr could chime in or else ill send guino or skippy a pm
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
    Dec 2003
    Greece
    The problem with running the .swf file is that I cannot load it from a different directory each time, in order to have different colors for DAY/NIGHT skins. I think that the flash movie has to be in the root RoadRunner directory in order to work in RoadRunner.
    I tried this but the flash did not load up.
    /, F, x, y, w, h, Movie name
    F,0,0,839,478,"c:\program files\road runner\DrawDay\draw.swf"
    This works OK, but I can have only one set of colors
    F,0,0,839,478,"draw.swf"
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Nice little app.
    couple of observations/requests
    1. when you press the save button can it move to the next screen/file (have this as a user selectable maybe.
    2. Can the buttons be done by keystrokes (then we can use sendkeys from RR)
    3. Button size and place be user defineable.
    4. Side panel size and placement be changed
  1. Attention Newbies! A FAQ to the FAQs
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-16-2006, 12:17 AM
  2. Replies: 9
    Last Post: 06-08-2006, 06:15 PM
  3. Replies: 19
    Last Post: 10-27-2005, 12:53 AM
  4. Just for laught: Computer and Car
    By MatrixPC in forum Off Topic
    Last Post: 01-05-2005, 10:25 PM
  5. Real Time Car tracking now working!
    By Magpie in forum GPS
    Last Post: 10-27-2004, 05:08 AM
