Results 1 to 2 of 2
Thread: Analog VU Meter to display cpu usage
    Jan 2006
    Hi,
    Do you know an app that can drive (thru com port?) an Analog Meter to display cpu usage ?
    Ben
    Variable Bitrate 84RegalRider's Avatar
    Nov 2004
    San Diego
    up to 24 mA i think is the max current .(probably not much higher if im wrong).
    so u would need to find an amp meter that would have max reading(100%) at 24ma (good luck) unless u could program a PIC and use it to turn relays on to set up the amps closer to a standard amp meter.
    SO i would say u need to get the phy part down.
    Core duo
    1tb harddrive
    256 ddr
    8 lilliput
    bu-353
    still installing...
  1. CPU temperature display in FrodoPlayer?
    By fireball106 in forum FrodoPlayer
    Last Post: 10-10-2005, 10:03 AM
  2. Hi CPU usage on certain MP3s.
    By ZenerDiode in forum FrodoPlayer
    Last Post: 02-27-2005, 03:13 PM
  3. Need Volt meter display on dash!
    By Joeweb in forum General Hardware Discussion
    Last Post: 06-25-2004, 01:39 PM
  4. Lilliput USB driver CPU usage question.
    By AustnJPR in forum LCD/Display
    Last Post: 04-06-2004, 02:59 PM
  5. winamp cpu usage
    By awh4992 in forum Software & Software Development
    Last Post: 01-07-2004, 11:13 AM
