Can I get the source then I shall fix it.
Printable View
hi clemens
watch this
http://www.car-pc.info/phpBB2/viewto...=130701#130701
thats what u need showgps 2.5 beta.
j.
Is it possible to move in one custom position all the background bitmaps image?
I want to set my X and Y position for this....
Mauri
Hey all, sorry I can't test the program right at this moment. I have no clue as of why it would be reporting the wrong data, but I have on the way a new GPS Rx like the one I have in my car. The BU unit and it works with it in my car.
I will look into the code and see what I can find out. And why it is reporting the wrong data.
Mauri, you want to move all the gauges at once? You need to move them individually the way I set it up, then once you have it where you want it, you can lock them. But they do work on x and y coordinates. So I can code it so you can choose the x and y for each one if you want.
clemen, try showgps 2.5 beta thats what u need perfect for your purpose..
j.
Hello Clemen!
You can make your own skin for ShowGPS.
Easy by mouse in the program.
Go to Options -> More Settings -> Displays+Instruments
Disabled all you donīt need.
Then go to Display and make sure that no other skin is in the textbox and that "Menu remove"+"in the foreground" is enabled.
Save all by OK.
Now, go to Surface-> Disabled "Lock Surface"
Move the Displays or Text in ShowGPS to the position you like and by this resize ShowGPS.
Then press Key F8 to Remove the Menu.
Start ShowGPS with F2.
Okay, its a little work, but now its simple. :)
Bye
My english is bad...
