Page 4 of 4 FirstFirst 1234
Results 31 to 39 of 39
Thread: GPSing - Digital Speedometer/Altimeter/Compass
  1. #31
    Jan 2004
    Can I get the source then I shall fix it.
  2. #32
    Aug 2006
    hi clemens
    watch this
    http://www.car-pc.info/phpBB2/viewto...=130701#130701
    thats what u need showgps 2.5 beta.
    j.
  3. #33
    FLAC mauri's Avatar
    Jan 2004
    Is it possible to move in one custom position all the background bitmaps image?
    I want to set my X and Y position for this....
    Mauri
  4. #34
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    Hey all, sorry I can't test the program right at this moment. I have no clue as of why it would be reporting the wrong data, but I have on the way a new GPS Rx like the one I have in my car. The BU unit and it works with it in my car.
    I will look into the code and see what I can find out. And why it is reporting the wrong data.
    Mauri, you want to move all the gauges at once? You need to move them individually the way I set it up, then once you have it where you want it, you can lock them. But they do work on x and y coordinates. So I can code it so you can choose the x and y for each one if you want.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
  5. #35
    Jan 2004
    Quote Originally Posted by LESLIEx317537 View Post
    Are you computer using imperial units, i was driving 53km/t today and it showed 5321km/t so maybe its a unit fail
  6. #36
    Aug 2006
    clemen, try showgps 2.5 beta thats what u need perfect for your purpose..
    j.
  7. #37
    Jan 2004
    Quote Originally Posted by jennico View Post
    j.
    No it isent, I just need the speed in text, and show is not simple enogh yo my purpose
  8. #38
    Newbie ShowGPS's Avatar
    Aug 2006
    Germany
    Lightbulb Oh, yes its simple...
    Hello Clemen!
    You can make your own skin for ShowGPS.
    Easy by mouse in the program.
    Go to Options -> More Settings -> Displays+Instruments
    Disabled all you donīt need.
    Then go to Display and make sure that no other skin is in the textbox and that "Menu remove"+"in the foreground" is enabled.
    Save all by OK.
    Now, go to Surface-> Disabled "Lock Surface"
    Move the Displays or Text in ShowGPS to the position you like and by this resize ShowGPS.
    Then press Key F8 to Remove the Menu.
    Start ShowGPS with F2.
    Okay, its a little work, but now its simple.
    Bye
    My english is bad...
    ShowGPS - CarPC / Laptop Tool - POI / GPS / Tracking / Map
  9. #39
    Jan 2004
    Okay I will try, do you need a danish translation of ShowGPS`?
    Quote Originally Posted by ShowGPS View Post
    Hello Clemen!
    Save all by OK.
    Bye
  1. SDPIF digital Coax into car audio pieces
    By RedGTiVR6 in forum Car Audio
    Last Post: 10-14-2008, 01:06 AM
  2. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  3. Coaxial Digital VS Optical Digital
    By MeeM in forum Car Audio
    Last Post: 06-01-2006, 01:55 AM
  4. SPDIF (digital coax) to Toslink (digital optical) convertor? Just curious...
    By coachreed in forum General Hardware Discussion
    Last Post: 04-27-2005, 11:33 PM
  5. Digital to Analog Converter
    By Maukio in forum Car Audio
    Last Post: 02-01-2005, 12:58 AM
