Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: US Traffic Cams 1.0 Beta
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    1.0 Beta now available on my forum
    http://en4cer.co.uk/forum/viewtopic.php?p=535#535
    US Traffic Cams v1.0 Beta
    Instructions
    Extract from the zip to your Road Runner (or any Front End) folder. Run
    TCSearch to find the code to the cameras you want. Put those codes into
    Trafficams.ini against cam1, cma2,cam3 etc. Then run Trafficams.exe. As
    long as you have internet connection and the cosen cameras are operational
    the camera pics should appear. Clicking on any pic will cause it to
    maximize, clicking again will go back to normal.
    To embed in RR simply create a skin with an Application box. A,x,y,h,w,192
    and then a calling button
    "load;traffic.skin;Traffic Cam;$rrpath$Traffic Cams.exe;Trafficams"
    Future Of Traffic Cam
    More cameras from around the country to added to the database.
    A central download location for the latest database.
    One EXE for all countries, just different databases.
    Current areas covered
    MA - Boston
    NJ - All
    NY - New York
    NY - Albany
    PA - Pittsburgh
    PA - Harrisburg
    PA - Philadelphia
    VA - Norfolk
    NC - Winston-Salem
    NC - Greensboro
    NC - Charlotte
    GA - Atlanta
    FL - Palm Beach County
    TN - Nashville
    IN - Indianapolis
    MI - Detriot
    IA - Des Moines
    WI - Milwaukee
    IL - Chicago
    MO - Kansas City
    TX - Houston
    TX - San Antonio
    TX - El Paso
    CO - Denver
    CO - Colorado Springs
    ID - Boise
    AZ - Phoenix
    AZ - Tucson
    NV - Las Vegas
    CA - San Diego
    CA - San Francisco
    OR - Portland
    WA - Seattle
    OHIO cameras will be in the next database version.
    Some will have better coverage than others, some will update more often. Also some may be out of date, if so let me know.
    If you know of any sources on the web for cameras in your area then give me the link and I'll try and add them to the database.
    Bug reports or Suggestions to
    admin AT en4cer DoT co DoT uk
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Wow, looks great (With your default camera's ) I cant seem to find any camera's in my area, even though "FL - Palm Beach County" is in your list of supported cam's.
    When I search for FL, I do not recognize any of the cities, they appear as though they could be English (England) city names.
    For example searching for FL I get:
    "Belgrave Flyover Leister"
    Leister is not a city in Florida that I am aware of, any suggestions?
    I tried various searches: West Palm Beach, West Palm, Palm, and various street names / intersections where camera's are located to no avail.
    EDIT: I just tried Seattle as in your example above, and no listing show up. (Also, I Did run the .bat to register everything)
    EDIT(x2): I have confirmed, that the database you included is indeed the one for England I did a search, using just the letter "S" and got the following results:
    Looks like we need the United States version of the "TrafficCams.E4D" for this side of the pond
    To help add to the database, Here are the camera images for West Palm Beach, Boynton Beach, Boca Raton, Delray Beach, Pompano Beach, Fort Lauderdale, and all of Miami (Basically all of Southeast Florida) on this ONE PAGE Click on the Traffic Cams Tab, the page is in frames. All the cam's are standard JPG's and the names & locations do not change, so they will be very easy to add to the database.
    My Fiero Build Thread
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    You are right Hopefully the cams above will help to add to the data base.
    I did just get this, after downloading the US version:
    It happened when the cams went to refresh. I could see a couple of them flicker, refreshing, then the error occurred.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Hmm.
    What OS are you running (I have only tested on 2000 at the moment)?
    Can you post your ini, and I'll try the same cameras here.
    Edit, make sure you run the US version, not the UK version.
    Maximum Bitrate david69leonard's Avatar
    Oct 2006
    Texas
    thats purty sick, i like, will try when i get home... Great work!!!
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Here is my INI:
    Code:
    [General]
    Width=800
    Height=516
    Delay=60
    [General]
    Width=800
    Height=516
    Delay=60
    [Cams]
    Cam1=E4002FC
    Cam2=E4002FF
    Cam3=E400303
    Cam4=E400305
    Cam5=E400307
    Cam6=E400309
    Cam7=E40030A
    Cam8=E40030D
    Cam9=E400311
    Cam10=E400315
    Cam11=E40036F
    Cam12=E40042D
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Hmm, apart from having the General section twice for some reason there should be nothing wrong with that.
    I have tested it here and do not get any errors.
    So it might either be your OS (which is . . . . . ?) or the way you connect to the internet.
    Try the UK version, they are exactly the same program, just look for differently named Database files at the moment.
  1. Garo's Extra POI Plugin 1.0 beta 1
    By garo in forum Map Monkey
    Last Post: 01-18-2007, 01:32 PM
  2. Problems installing Girlfriend 1.0...
    By gospeed.racer in forum Off Topic
    Last Post: 10-18-2005, 06:17 PM
  3. Replies: 33
    Last Post: 10-18-2005, 02:38 PM
  4. Replies: 4
    Last Post: 08-12-2005, 10:51 AM
  5. Remote Playlist Manager for Frodoplayer - 1.0 Beta 1
    By PatO in forum Software & Software Development
    Last Post: 03-17-2005, 02:58 AM
