I had the same problem - you will also notice that it will go through the wizard no matter what you select from the phoco start sub-menu. the shortcut on the start menu all point to the same file - so I fixed it by making it point to the right one - dont recall the file name but just go to the phonocontrol.net folder in Program Files - the name of the correct exe file is fairly obvious.
LinkBack URL
About LinkBacks
