This is a problem with some BT Adapters ... it happens on mine on my laptop, only way round it seems to be to try another BT Adapter .... sorry.
Hey i installed the widdcom divers all corectly and i get connections from PC to Phone. I did you tutorial on the BT Serial Port it conects. But when i go to phone test and click on the com port my phone is on i get The blue screen of death. Everytime phoco tries to connect with my phone i get the blue screen of death....any1 know what the problem can be?
really....the error i get is
IRQL_NOT_LESS_OR_EQUAL
hmmm, not the same problem I was getting, will have a think to see if I can come up with a possible solution for you.
are you using hacked drivers by any chance? Some of the bt devices dont work right with the hacked drivers. I have 2 bt dongles and one of them hates the hacked drivers while the other dosent care at all. The one that hated the hacked drivers would also bluescreen windows when i tried to connect with phoco, and any other app, but not if i made the connection manually through MyBluetooth Places.
Installed the non hacked drivers and everything was cool.
driver version makes a difference too, because the same device now has no problem with the latest hacked drivers.
I would suggest, if your still haveing this problem. Completely uninstall all bluetooth drivers, reboot. Check device manager and make sure anything related to bluetooh is uninstalled. reboot. repeat above. install the latest official drivers (non hacked) and make sure your bluetooh com port is not higher than 16.
