Page 102 of 122 FirstFirst ... 2529293949596979899100101102103104105106107108109110111112 ... LastLast
Results 1,011 to 1,020 of 1211
Thread: Custom USB tyre pressure monitoring interface
  1. #1011
    FLAC WuNgUn's Avatar
    Sep 2007
    Which reminds me...
    Today I went about 'learning' my sensors, seeing that I have all 4 working now...
    But I'm a little confused, as I rotated my tires (front to back) before I learned them. The colour marking is swapped front/rear now.
    The problem is, I learned the sensors matched to the colour coding, so using RRTMS, the rear left and right are number 1 and number 2...Front is 3 and 4...
    No problem learning them like this, HOWEVER, when setting up sensor assignments in Centrafuse, should I select the numbers the same as RRTMS, i.e. front left/right = 3/4, etc., or should the assignments stay the same, 1 thru 4?
    In other words, is CF reading the data as it's learned from RRTMS, or is it assuming front left is always 1, front right 2, etc.?
    I think I have the CF plugin really confused...or I'm really confused!
    I have to mess with the PSI to find out whats really going on...
    Or just 'learn' it regardless of colour coding, and simply learn them in the proper order, 1, 2, 3, 4... (and swap the colour rings around!)
  2. #1012
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by WuNgUn View Post
    Dunno about the CF plugin or you, but I's cerrtainly confused.
    Which is really worrying considering my Custom Title.
  3. #1013
    Lok
    Lok is offline
    VENDOR - Portal Media Lok's Avatar
    Feb 2008
    Regardless of what program you use to learn the sensors you writing ID's to the recievers internal memory, so the first time you learned the sensors I would assume that 1-FL 2-FR 3-RR 4-RL 5-S. Now that you have rotated your tires (Lets assume you used the traditional rotation patter for rear/4 wheel drive cars as you have a Durango, use this site as reference http://www.tirerack.com/tires/tirete...jsp?techid=43& Pattern C) your order should now have changed to 1-RR 2-RL 3-FR 4-FL 5-S. There is no way for the reciever to know where your sensors are...yet .
  4. #1014
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by Lok View Post
    LMFAO...... I have a Durango silly, and I have the 2 Wheel Drive one, couldnt find a decent 03 4x4 in the year 2007 when I bought the car.... WuNgUn has a Ford Focus......
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  5. #1015
    Sep 2007
    Okay...I'll relearn them using RRTMS using the standard 1-FL 2-FR 3-RR 4-RL pattern...
    Then use CF to configure where the tires are...
    My tires are directional, so they only move forwards and backwards when rotated, not X cross
  6. #1016
    Feb 2008
    anyone know where i can get a pre-etched bread board and a programmed pic chip? i am going to hook up this receiver http://www.sparkfun.com/commerce/pro...oducts_id=8947
    going to see if i can pick up my sensors to start getting samples of packets so we might be able to decode them. the hope being maybe we can expand this for use with cars that already have sensors
  7. #1017
    Sep 2007
    Okay...reprogramed the sensors again today, this time without altering the locations.
    Reprogramed easy, thanks to the new hardware!
    Everything seems to be working well...
    However, I have the reciever mounted in the dash behind the monitor, and I'm not sure if it's picking up the sensors. The data seems to never change!
    (I programed it with the reciever on the dash, so I can 'reboot' it after each 'learn')
    Is there a way to know if it's reading 'new' data, or just displaying the 'learned' data?
    Perhaps this could be a future feature...to have the TPMS tell you if it hasn't recieved any new data after X amount of minutes?
  8. #1018
    Lok
    Lok is offline
    Feb 2008
    Do you have the LED version of the board??? If so then there are two LED's on the device, one should remain on once the USB link has been established and the other should blink every time you recieve a new packet.
  9. #1019
    Lok
    Lok is offline
    Feb 2008
    Quote Originally Posted by Xargon321 View Post
    I would talk to the forum member Dejan about that. I don't think he has been selling them much since the new USB TPMS came out but he may still have a pic chip and a board laying around. Also just so you know the PIC chip is protected so you won't be able to read the firmware. I am interested to see where you go with this development as I have had many people ask me if their TPMS will work with stock systems. Be sure and e-mail me if you need help, I might be able to give you some pointers.
  10. #1020
    Sep 2000
    LA, CA, USA
    I don't think you should waste any time on a pre-programmed chip just follow the links on the sparkfun product page to get it hooked up via serial and start reverse engineering the protocol. There is no reason we shouldn't have a receiver for < $50 and the whole system for < $150.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. USB self powered hub, which one
    By htsource in forum General Hardware Discussion
    Last Post: 07-26-2007, 04:31 PM
  3. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  4. USB Earthmate - patch for gpsd support
    By dignome in forum GPS
    Last Post: 04-05-2005, 11:44 AM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
