Az1324 I think you are hoping for a bit too much. These receivers are being built in runs of 100 boards, there is simply not enough volume to reduce the costs to that point. If I could make a run of 1000 boards the cost of the kit would easily be less than $150.
@ Xargon, i think Ax1324 is right, you won't need the PIC chip as the protocol is probably completely different. The learning process may even differ significantly. You need to get a logic analyzer and see what kind of communication is going on in your exisiting TPMS system, chances are you may need to tap into your actual TPMS electronics and see the 1's and 0's that are being transmitted on the frequency. You may not be happy with how your car looks at the end...
LinkBack URL
About LinkBacks
