Page 104 of 113 FirstFirst ... 454949596979899100101102103104105106107108109110111112113 LastLast
Results 1,031 to 1,040 of 1130
Thread: Custom USB tyre pressure monitoring interface
  1. #1031
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Robby BMW View Post
    Maybe the touchscreen generates a kind of interference that prevents the reception of the sensors.
    Very likely.
    I have found it already affects my remote central locking.
    For a while I had my screen powered off the PC and it stayed when the key was out of the ignition. The range dropped to about 10 inches (25cm) above my bonnet.
    Now the screen is back to being switched from the ACC so as soon as the key is out the screen goes off. Now the Remote works as normal from across the street.
    Get some shielding on that/those screens.
  2. #1032
    Constant Bitrate lacning74's Avatar
    Apr 2008
    Quote Originally Posted by Enforcer View Post
    Very likely.
    dude! that's why! i thought my key fob battery was dying. now it works again, and "coincidentally" after i had my touchscreen switched to ACC as well.
    hmm, when i moved my TPMS receiver box further back away from the touchscreen closer to my 4th sensor, it started refreshing again, though sometimes it still gets stuck with old data especially when my kids are loaded up in the back. maybe my baby boy emits some sorta of interference with his cries?
  3. #1033
    FLAC WuNgUn's Avatar
    Sep 2007
    Well, I went out and bought a 6ft USB extension...I put the TPMS reciever behind the sunroof motor access door (basically, center-forward ceiling), and it's picking up the sensors and updating regularly now...Weeee!!!!
    But I think left rear is still a BIT distant, as it was the slowest to update.
    All-in-all, a much better setup!!
    Thanks for the help guys!
    BTW, when it was in my dash, and struggling to read the RF data, I got problems with the plugin again...sluggish CF respones, and the occassional freezing.
    Seems better in this respect now, however...
  4. #1034
    Jul 2006
    where can i get TPMS doctor software?
    I checked the whole site, but can't find download links anywhere.
  5. #1035
    Jul 2006
    hahaha...stupid me...i searched the wrong area.
    Never mind.
    Anyway if anyone else wants to know.
    Here is what looks like the official release.
    Info and download for TPMS Doctor v1.3 (at time of this post)
    http://www.mp3car.com/vbulletin/port...ml#post1171817
  6. #1036
    Sep 2007
    Still having problems picking up the rear left sensor most times...
    Would extending the antenna help, or is it s'pose to be a fix length?
  7. #1037
    Apr 2008
    Quote Originally Posted by WuNgUn View Post
    i still have occasional problems with my rear left (sensor 4) updating as well. i'm wondering if it's not just an issue with the antenna reception since my rear right never has a problem and they are equidistant. maybe the way the software/hardware cycles or something?
  8. #1038
    Lok
    Lok is offline
    VENDOR - Portal Media Lok's Avatar
    Feb 2008
    Have you tried re-learning the sensor? You don't have relearn all of them just the one you are having issues with, this usually takes care of refresh issues. Also distance isn't everything, there are a number of causes of interference in a car so there might be something on your rear left that is causing intereference. The other option you have is to boost the antenna reception by using a more robust antenna such as one from antennafactor.com. I have a prototype here in which I was able to extend the range to almost 15m using an upgraded antenna. Hijack also has one of these prototypes and I believe MrBean also did a little upgrade himself so you may want to talk to one of them and see what they think as well.
  9. #1039
    Lok
    Lok is offline
    Feb 2008
    I would not mess with the antenna length as it affects reception. 433 Mhz Antennas have to be approx 6.5 inches. If you search this thread Robby has posted the exact length in one of his posts.
  10. #1040
    Sep 2007
    Quote Originally Posted by Lok View Post
    Then perhaps a straight, hard-wire antenna would be better for reception? Or trying to get the wire antenna as straight as possible?
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 10:30 PM
  2. USB self powered hub, which one
    By htsource in forum General Hardware Discussion
    Last Post: 07-26-2007, 03:31 PM
  3. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 03:24 PM
  4. USB Earthmate - patch for gpsd support
    By dignome in forum GPS
    Last Post: 04-05-2005, 10:44 AM
  5. Replies: 4
    Last Post: 04-06-2004, 09:52 AM
