Page 106 of 114 FirstFirst ... 65696979899100101102103104105106107108109110111112113114 LastLast
Results 1,051 to 1,060 of 1131
Thread: Custom USB tyre pressure monitoring interface
  1. #1051
    May 2008
    Bend, OR
    Might anyone have a close up of the soldering job to connect the pin at R9? I'm about to cut my board and want to A: make sure I cut it correctly, and B solder the pin on the correct side of the resistor.
    Reason I ask is Robby's original pic it appears to bridge the resistor so I'm not sure.
    Thanks,
  2. #1052
    May 2008
    I asked the same question when I first made mine up. If it's the resistor I think you mean then you can remove it as it's not needed which is why Robbies pics seemed to show him bridging over it, it's not needed was the answer I got and mine didn't seem to work when I left it in at first now they do so...........
  3. #1053
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    ok i've not posted on this thread in agesssssss, but i did buy the system, its worked in my car fine, i now want to add the usb option.
    whats best way to move on, who if anyone is doing the boards/pics etc.
    dont make me read back through all these pages lol, i've had the kit a year since the initial start of the thread, too much reading!
    Lez, more widely known as flez1966
  4. #1054
    FLAC WuNgUn's Avatar
    Sep 2007
    Hey Alok...
    System has been functioning beautifully...until today.
    It started telling me the front right (one of the new sensors I bought from you) sensor battery is dead...no pressure showing, and reading 120 degrees celcius.
    Could the sensor actually be toast? Or maybe a software issue?
  5. #1055
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by WuNgUn View Post
    Try spreading some butter on it and see how it tastes.
  6. #1056
    Lok
    Lok is offline
    VENDOR - Portal Media Lok's Avatar
    Feb 2008
    Hey Alok...
    I have two suggestions for you:
    1.Try re-learning the sensor and see if starting picking up correct data, there is no way the battery can be dead that quickly, even the sensors I use for testing for the last two years still haven't run out.
    2. The sensor may have actually broke from hitting a speed bump, incorrect installation, or a pothole.
  7. #1057
    Sep 2007
    Hahaha...butter...funny!
    I'll try a relearn and cross my fingers!
    Thanks...
  8. #1058
    Sep 2007
    Just a FYI..I relearned the 'bad' sensor, and it picked up and started functing correctly...awesome!
  9. #1059
    Apr 2006
    Sydney, Australia
    Thinking of adding this to my carpc setup, just curious to know the following, as not 100% if it's been asked or mentioned..
    [1] How long is the battery life of the sensors and can they be changed
    [2] Will having WiFi, BT, GPS, RadioTuner affect operations of the USB TMS
    [3] Will these fit to any car wheel(RIM)
    [4] Anyone got these in Sydney Australia, where's the best place to buy besides mp3store?
    [5] Has anyone invented the use of the rotating wheel to charge up the batteries?
    [6] Will a sensor know which tire it's in? Maybe in future versions, if so when?
    Kosti
  10. #1060
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    [1] Approx 5-6 years , no
    [2] Possibly, I have noticed seems WiFi seems to affect it, but have not 100% proved it yet
    [3] Would say no, because there bound to be at least one type of wheel it won't fit.
    [4] n/a
    [5] Not really worth considering the batts last 5-6 years.
    [6] It does when you program the receiver
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 10:30 PM
  2. USB self powered hub, which one
    By htsource in forum General Hardware Discussion
    Last Post: 07-26-2007, 03:31 PM
  3. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 03:24 PM
  4. USB Earthmate - patch for gpsd support
    By dignome in forum GPS
    Last Post: 04-05-2005, 10:44 AM
  5. Replies: 4
    Last Post: 04-06-2004, 09:52 AM
