Page 107 of 113 FirstFirst ... 757979899100101102103104105106107108109110111112113 LastLast
Results 1,061 to 1,070 of 1127
Thread: Custom USB tyre pressure monitoring interface
  1. #1061
    Apr 2006
    Sydney, Australia
    Thanks for the reply!
    [3] What options are available if it dont suit a wheel?
    New Car PC Build list in progress
  2. #1062
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Well the sensor fits onto the supplied valve, which should fit most wheels, but I can cases where it won't due to the size and the way the wheel maybe made.
    I guess you can try and strap it to the wheel.
    or somehow stick it, but that would be highly unreliable and you may find you end up with a rattle in your wheel.
  3. #1063
    Constant Bitrate lacning74's Avatar
    Apr 2008
    I've been having to relearn my sensors more and more it seems. They get stuck on readings for days or read super high incorrect PSIs and temps. After master reset and relearn the readings work again.
    This is becoming a pain. I would like to install and forget.
  4. #1064
    Maximum Bitrate vicky_obee's Avatar
    Dec 2003
    Hi
    Can some 1 pls help me with the TPMS software ( by Roby )
    well the sensors work fine and shows the press and temp...
    but for some reason i am not getting the Batt indication ( it shows empty ) nor am i getting the audio warnings ( of course its not mute )
    Can some 1 pls post in there copy of this working INI file
    Vicky
    Commell LV-677 DC 6 x 6" Mother Board
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    7" InDash Xenarc MTD - X7000 Screen
    Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
    Parrot MK 6000 & iPhone
    Re done the carputer...Into the Glove Box !!
  5. #1065
    Jul 2006
    Quote Originally Posted by vicky_obee View Post
    Hi
    Vicky
    You should write out everything you did in step-by-step format. And what skin, rr version, etc..., your running.
    At this point no body knows what you did or didn't do.
    This way we can fill in the blanks.
  6. #1066
    Dec 2003
    HI Well i am running the latest ver of RR + DFx 4
    the skin is the original one made by Robby .. ( No Mods )
    Have not changed any codes or seq of the INI files or jpegs... or the batt folder
    just followed the step by step inst to install and run..
    The temp & Press indications work fine but the batt shows empty and no audio warnings
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
  7. #1067
    Constant Bitrate almera's Avatar
    Aug 2004
    What other plugins are you using? I believe you're using a plugin that causes this problem. Try disabling the other plugins to find the cause. For me, Velleman K8055 plugin causes the indicator problem.
  8. #1068
    Nov 2009
    Hello!
    Now i had read the hole thread.
    Wow, very much information!
    I had some questions to actual USB-TPMS-System!
    Quote Originally Posted by Lok View Post
    I just wanted to let everyone know that USB TPMS kits are in stock and available for purchase on the MP3car online store. These kits are V2.20 and have LED indicators for valid data packets and USB link. Technical support will be handled on the forums. If you have any questions regarding the product please don't hesitate to ask!
    Whats the newest Version available?
    On Portal Media Store only V2.0 is online:
    http://www.portalmediapc.com/store/12-tpms.html
    But on mp3car.com-store V2.2 is online:
    http://store.mp3car.com/ProductDetai...0&Show=ExtInfo
    Why?
    And the other question:
    If i will buy the V2.0 or V2.2, is it possible to apply TPMS-Doctor an the RR-Configtool also like with the first Versions of the USB-TPMS?
    I hope someone can help me!
    Thanks,
    greetings from germany,
    Ottmar
  9. #1069
    FLAC WuNgUn's Avatar
    Sep 2007
    CF3 support coming?
  10. #1070
    Dec 2003
    Hi Guys
    I amstill stuck with battery showing EMPTY and NO audio warnings ( speaker on, vol full )
    can some 1 pls be kind enough to post me a working copy of RRTPMS INI so day i can compare / edit and get it working on my end....
    My config.... Windows XP + RR + DF4 + robbys tmps ( no mods what so ever )
    Many thanks in advance
    BTW if i use CF i do get batt signals ( full ) and also the voice warnings.. So i guess it has to be the config ini of rrtpms
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. USB self powered hub, which one
    By htsource in forum General Hardware Discussion
    Last Post: 07-26-2007, 04:31 PM
  3. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  4. USB Earthmate - patch for gpsd support
    By dignome in forum GPS
    Last Post: 04-05-2005, 11:44 AM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
