Thread: Custom USB tyre pressure monitoring interface
  1. #1131
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    3rd eye TPMS kits (fresh kits not old stock) and Robby's pic chips are now in stock if anyone wants to make a board. SNO
  2. #1132
    FLAC WuNgUn's Avatar
    Sep 2007
    Not to hijack, but I have a completed, working board for sale...but no sensors.
    If anyone is interested, you can check it out I. The classifieds or PM me.
    Jan 2006
    Dublin, Ireland
    Does this plugin only work with the "3rd eye" hardware ? And then need a Robby receiver ?
  4. #1134
    Nov 2009
    Keswick,On Canada
    You are correct. It only works with the 3rd eye kit and you need the board and chip from robby's post. You can make your own board using robby's schematics or buy the portal media kit complete or I have designed a board that has a few more things on it as well as the TPMS. I have the chips and the 3rd eye kits should you decide on making your own board. Hope this helps SNO
  5. #1135
    Dec 2007
    Mohnton, PA
    Sorry to revive an old thread, but Google isn't yielding what I was hoping for.
    Are there any source codes out there to support this? I want to integrate this into my own current .NET project rather than use a separate canned application.
  6. #1136
    Nov 2009
    Keswick,On Canada
    There is no source code for the pic chip, that is proprietary to Robby. The data from device has been posted at the beginning of this thread. I have the pic chips if you need one. Good luck SNO
  7. #1137
  8. #1138
    Dec 2007
    Mohnton, PA
    Quote Originally Posted by Enforcer View Post
    If you want source code for the plugin, look at the RRTMS plugin by Robby.
    It's in VB6 but I'm sure you can easily convert to .net
    Got it, and converted it. Thanks.
  9. #1139
    Dec 2007
    Mohnton, PA
    Is there a way to re-learn a sensor?
    I just got this thing yesterday, and opened up TPMS doctor. Everything was showing. Then I got a generic HID application to look at the raw data, and now in TPMS doctor, Sensor #1 shows -98kpa for pressure, -32C for temp, and status is ?. Battery level is also only showing 2 bars, when yesterday it was showing full. I don't know what using a generic application would have done, but if this thing is that sensitive, then maybe I'll just return it. I see Robby doesn't even come around here anymore, so I assume there is no longer support for his product?
  10. #1140
    Nov 2009
    Keswick,On Canada
    RRTPMS or CF-TPMS can relearn sensors. Robby hasn't been around much in the last few years, I am still in contact with him once a year at least and I carry the pic chips in stock. As for software support that would be up to individual plugin developers for RR and CF but it also works fine in Driveline without plugin. Good luck SNO
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. USB self powered hub, which one
    By htsource in forum General Hardware Discussion
    Last Post: 07-26-2007, 04:31 PM
  3. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  4. USB Earthmate - patch for gpsd support
    By dignome in forum GPS
    Last Post: 04-05-2005, 11:44 AM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
