Page 118 of 118 FirstFirst ... 1868108109110111112113114115116117118
Results 1,171 to 1,178 of 1178
Thread: Custom USB tyre pressure monitoring interface
  1. #1171
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    I got this from the first post, hope it helps SNO
    Sensor state (8 bits): The bits 0 and 1 of this byte contains the following information:
    00 = Initial mode (Pressure is measured every 0.85 seconds and data is sent every 0.85 seconds. This sequence is repeated 256 times)
    01 = Normal mode (Pressure is measured every 3.4 seconds and data is transmitted every 60 seconds)
    10 = Pressure alert mode (Pressure is measured every 0.85 seconds and data is sent every 0.85 seconds. This sequence is repeated 256 times)
    11 = Temperature alert mode (If the temperature exceeds 120C, the sensor device enters into the same measurement and transmitting pattern as the pressure alert mode)
  2. #1172
    Dec 2007
    Mohnton, PA
    Right, but that's what the receiver gets. My application "polls" the receiver for data, so unless the data changes, how does it know that it received something new?
  3. #1173
    Nov 2009
    Keswick,On Canada
    Well technically unless something changes not much needs to be done or even if it matters. Basically what I am saying is unless the pressure drops/temp rises there is no need for anything to change and is not something I am concerned with. Nothing changes = all good with my tires. I think your app could get pretty bogged down looking for time differential changes in reporting. And if pressure does drop or temp changes, the app will reflect those changes by updating the data. Maybe I am not seeing what you want to achieve or the merits of having such info available. Clockwork or Enforcer might be able to chime in for more detail or info. Good luck SNO
  4. #1174
    Dec 2007
    Mohnton, PA
    Quote Originally Posted by SNOtwistR View Post
    I'm probably not explaining this properly. Sorry about that.
    Whether or not the USB receiver actually receives a signal, it stores the last values received. I could be 100 miles away, and it will still readout 36psi on my tires. Therefore, whether the signal is lost or the data doesn't change, I have no way of knowing.
    What am I missing?
  5. #1175
    Nov 2009
    Keswick,On Canada
    I think you might have to ask Clockwork or Enforcer on this as using Driveline as I drive I see the temperature change as tires warm up as well as the pressure slightly increases as well as tires warm up. So they are receiving the signal or polling for it somehow to have these reading updating as I drive. I think I have hit the limit as to how I can help. Send a PM to Clockwork. He said he would try and help you out, although it would be nicer to continue it here to help others in the future solve these issues. Good luck SNO
  6. #1176
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    From what I can tell, there is now way of knowing from the sensor that the data is new or old.
    I have just added to my version of the RRTPMS plugin a bit of code that looks for any change in the three measurements and if so updates the last updated date flag.
    Whilst the pressure and battery levels may not change much, I'd be surprised if the temperature always stays the same.
    So if the temperature never changes I would have to guess the data hasn't been updated for a while.
  7. #1177
    Maximum Bitrate Dave One's Avatar
    Mar 2005
    Norfolk UK
    E, how much is a kit in the UK (damn you keep tempting me, lol)?
    Vauxhall Astra SXi Car PC installed.
  8. #1178
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Dave One View Post
    That's the thing.
    There is no one that I know that does them in the UK
    I got mine in a Digital-Car group buy years ago.
    MP3Car do them.
    Plus you can get them on Amazon (but it's from a US supplier and the the postage is horrendous)
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 10:30 PM
  2. USB self powered hub, which one
    By htsource in forum General Hardware Discussion
    Last Post: 07-26-2007, 03:31 PM
  3. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 03:24 PM
  4. USB Earthmate - patch for gpsd support
    By dignome in forum GPS
    Last Post: 04-05-2005, 10:44 AM
  5. Replies: 4
    Last Post: 04-06-2004, 09:52 AM
