Waiting for my PIC from Robby, I've got my PCB already assembled, we'll see how it works with the Valet
Let us know if it works correctly (Stand alone or in RR). I have the VALET unit. If you get the data on your screen, that is a start. I will order one from Robby and go from there. Thanks
TruckPC - gutted, being used for test setup
BoatPC - off season - Inelmac screen needs serviced again!
BlazerPC - last vehicle PC I'll build
Just got my board from _Dejan_ high quality work.
I will complete the mod later this week.![]()
I've been up and down this thread many times...and yet I feel like I still don't know where to start.
I know which sensor kit I need (I think)...so what's left?
Dejan makes a printed board with the parts? Or all parts minus the PIC? I need to get that from Robby? Is it programmed? Just build the board and go?
Any help with this would be appreciated...
I purchased 3rd eye TPMS using discount coupon from juve021, ordered board from _Dejan_ . Use the provided link to see what I did.
http://www.mp3car.com/vbulletin/1153329-post173.html
I am using RR and DigitalFX skin. Since I started on this project there seem to be a less expensive alternative available.
But this is what I did.
Hope it helps.
Rob and Dejan have this setup only for the 3rd Eye kit, right?
Cause that kit is expensive...
I poured over the thread again and noticed the VALET system. Is this the less expensive solution your talking about?
Has anyone put this together using the VALET setup?
Hi,
Me, Robby and mnwcsult are using 3rd eye TPMS kit. We are not test any other kit... So if there is someone who is successfully build setup with any other TPMS kit please tell us how can we build it...
I am glad to see that you are happy with Robby's and mine work...
Bye, _Dejan_
If the learning proces terminates as expected by deflating or inflating the tires (without push the Abort button), it means that the circuit is working.
However, given the need of many users, I will write a little stand-alone program able to check the circuit without RoadRunner.
_______________________________________
Car installation 95% [■■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
