Page 24 of 122 FirstFirst ... 14151617181920212223242526272829303132333474 ... LastLast
Results 231 to 240 of 1211
Thread: Custom USB tyre pressure monitoring interface
  1. #231
    Mar 2005
    Wiesbaden/Germany
    Quote Originally Posted by Robby BMW View Post
    If the learning proces terminates as expected by deflating or inflating the tires (without push the Abort button), it means that the circuit is working.
    this means it has received a valid (crc check successfull) paket ?
    However, given the need of many users, I will write a little stand-alone program able to check the circuit without RoadRunner.
    just show every received message somewhere in your config tool...
  2. #232
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    I've received my PIC, and have everything assembled. The config program recognizes the hardware. Now I just need to mount the sensors in some tires to see if I am receiving data.
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
  3. #233
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by WuNgUn View Post
    Rob and Dejan have this setup only for the 3rd Eye kit, right?
    Cause that kit is expensive...
    I poured over the thread again and noticed the VALET system. Is this the less expensive solution your talking about?
    Has anyone put this together using the VALET setup?
    Considering all the other stuff that has gone into the CARPC another $250.00 isnt that bad. I actually like the 3rd eye kit, I may buy it and use it as is (I dont think I can connect it to the PC like you guys have, I suck at mods).
    Now is this mod via USB? Is there a Serial (COM port) mod? I have 4 USB ports all being used. 3 for high bandwith, then a 7 port hub which is also filled. I really dont want to add another HUB so a serial would be great.
    Also, what exactly do I need.......... I have to order the the whole TMPS from viva, or only the tire sensors? Also the board I order from Dejan? What is a PIC? Can I order that too?
  4. #234
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Quote Originally Posted by HiJackZX1 View Post
    Hi,
    You need whole TPMS kit(because you need receiver to), USB board(which you can get from me or you build it yourself), programmed PIC(you can get it from Robby), case for builded TPMS, USB cable and this is all
    If I remember Im somewhere see converter from Serial to USB so maybe this will be solution for your problem but I think maybe will be better if your GPS or if you have OBDII will be connected by this Serial to USB interface, because I dont think if software will work...
  5. #235
    Feb 2006
    Melbourne, Australia
    I've been up and down this thread many times...and yet I feel like I still don't know where to start.
    I know which sensor kit I need (I think)...so what's left?
    Dejan makes a printed board with the parts? Or all parts minus the PIC? I need to get that from Robby? Is it programmed? Just build the board and go?
    Any help with this would be appreciated...
    Ok, let's make it easy on everyone who needs to know what to get:
    The best solution, by far;
    1) Get the complete USB interface from DeJan, which will include Robby's PIC Micro with propietary code, pc board, crystal oscillator, ie the complete USB interface to your PC, but no Tyre Pressure System yet.
    2) You have to buy the 3rd Eye System from a supplier, ie one that was mentioned here earlier.
    3)Then you need to desolder the RF Receiver on the LCD board of the TPMS kit, and mount (solder) it to the USB interface you receive from DeJan.
    4)Take your car to a tyre-shop, and have the sensors fitted, and wheels rebalanced.
    5)Load the software from Robby's link to your PC, and there you go - you need RoadRunner as a front-end to run this software, but Robby is writing a small test-routine that will check your system for correct operation.
    If you do not want to use RoadRunner as a frontend, but rather Centrafuse, DeJan's friend is currently writing a plug-in for CentraFuse.
    Easy as pie, all the hard work has been done for us, it is virtually plug-and-play.
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
  6. #236
    Nov 2007
    Sydney, Oz
    Quote Originally Posted by mrbean_phillip View Post
    {quote]I've been up and down this thread many times...and yet I feel like I still don't know where to start.
    Easy as pie, all the hard work has been done for us, it is virtually plug-and-play.[/QUOTE]
    Mr Bean, You make it sound so easy, I am ready for you to do mine now.
    Do you take Amex?
  7. #237
    Feb 2006
    Hehe, I can help you, no worries
    Sydney is just around the corner after all, and I can ship it out if you order everything and send it to me?
    Keep me posted, I am about to order the TPMS kit from Viva Performance, but their shipping options is very expensive, I am hoping they would do USPS for us, I am not really willing to pay $121- US for shipping.
  8. #238
    May 2006
    Belgium
    this is idd easy as pie
    but i still have one question: we need to buy the tpms kit (for example from viva performance) witch costs 250 dollar, and then we modify it a little so we only use the receiver and the sensors from it?
    isn't there a way to buy just the sensors (100 dollar) and get the receiver somewhere else? i think it is possible to get it made for under 150 dollar right? or am i wrong?
    Greetz
    Dj NRG
  9. #239
    Sep 2007
    LA
    FMode and DaveDog:
    Looks like you two are both at the same stage. I am eagerly awaiting your results as I plan on purchasing the Valet system and attempting this project. Let us know what you find out. Cheers and good luck.
  10. #240
    Jan 2008
    MD, USA
    WOW!! Subscribed.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. USB self powered hub, which one
    By htsource in forum General Hardware Discussion
    Last Post: 07-26-2007, 04:31 PM
  3. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  4. USB Earthmate - patch for gpsd support
    By dignome in forum GPS
    Last Post: 04-05-2005, 11:44 AM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
