Looks great Robby!
Can you verify which Rf-chip is on your receiver board? Is it the same TDA5200 ASK Receiver, or not - if different, can you give us a part number, please FmodeOriginally Posted by Fmode
F6 Tornado Project Log ; HP Blackbird Watercooled Server
Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
Looks great Robby!
cashtexts - Earn money for receiving text messaged offers
cashtexts review not a scam
Space Navigator - 6 Axis input device: Take it apart - Driver App
RRCam - Video/webcam capture, text overlay, and recording: 2.0 Stable
@ Almera: Are you running Roadrunner when you launch the Configurator?
You have to - just launching the configurator without running RR frontend will not "detect" any id's from any wheel-sensors.
As soon as you foolow Robby's install-tips in the RR plugin forum, and then launch RR, and then the configurator, you can press the "learn" button for any sensor, and it will blink a few times, and then stop blinking.
After a short while, you may see some flashing red alarms in RR on the TPM screen, indicating - press and temps, albeit incorrectly, meaning that the sensors is communicating to the PIC, and the PIC to the plugin s/ware on your frontend.
the problem is there is no number on this receiver... and I can't look inside (if you are really interested I can try to get a small hole...)...
your TDA5200 will need analog discrete partsto work... but you are a very tough I guess
or didn't you find a source for complete receiver-modules ?
Here is one:
http://www.funkmodul.com/funkmodule/empfaenger.htm
you should take ERX-06 because it has the max. sensitivity...
Where did you get your tire sensors ?Why don't you buy the Waeco Kit with Receiver ? (4 sensors = 99 Euro , 4 sensors+receiver = 99 Euro ) (or do you want to build/sell a finished kit ?)
Erm, I have the 3rd Eye kit, and I made one working setup based on Robby's PIC, but I am just interested to know if yours use the Maxim IC or the TDA chip - my bet is your's is very similar to the ERX-06 you linked to....
I would like to develope a smc solution, which includes RF Receiver, Robby's PIC (but SMC) all onto one pcb, which would make it easier, cheaper, and much smaller.
Just luv tinkering, that's all
edit: There is a very nice Max1473 evaluation kit available, which I can very easily adjus to suit our needs, and provided Robby can provide TSOP 18F2550's, it would be very easy to do an industrial-grade, robust design
I am awaiting pricing on the eval kit, will keep everyone posted.
Thanks, actually I have succeed in the learning process, but still can't see any data in RR. Checked plugin configuration also, seems ok. Maybe something wrong with my hardware, thanks for help, cheers
Ok guys, the new software is availabel for the download here.
Change Log:
1.00
- First release.
1.10
- Fixed the discrepancy between the pressure detected and the raw data displayed.
- Fixed a little issue with the detection of the battery level.
- Improved the description of operating state of sensors.
1.20
- Fixed a another issue with the detection of the battery level.
1.30
- Fixed a bug with the USB buffer.
_______________________________________
Car installation 95% [■■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
Thanks Robby, I will try it..
