Page 29 of 113 FirstFirst ... 19202122232425262728293031323334353637383979 ... LastLast
Results 281 to 290 of 1127
Thread: Custom USB tyre pressure monitoring interface
  1. #281
    Feb 2006
    Melbourne, Australia
    @ Per: Look at Robby's post 268 on the previous page, he posted a link to a standalone test program there, which is the same as the screenshot you see above from Fmod - it is a different application to the config for Roadrunner.
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
  2. #282
    Mar 2005
    Wiesbaden/Germany
    2. testrun now on the street while driving for 10 minutes but no changing of any values...
    (with your PIC in an experimental stick-board and connected to the WAECO receiver just lying freely in my trunk)
    Where do those values come from which are displayed - they appear if I connect the PIC thats for sure ! Are these values from the EPROM ? Did you earase my EPROM before you send me the PIC ?
    Its not really necessary for me to get this running (WAECO) with your PIC but I think the forum is interested...
  3. #283
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    Quote Originally Posted by mrbean_phillip View Post
    That clears a few things up, thanx Robby
    So we can actually use the config without RR, which is what I first tried, but it did not do anything for me - only after having RR installed, and the app running, could config tool stop flashing abort sequence....
    But, probably 99% something I have done wrong with the pairing process then, will check it out and feedback.
    Thanx.
    Probably it was only a coincidence, moreover the configuration tools should be always used with roadrunner closed in order to prevent conflicts between the two programs and the USB comunication.
    However, at the end are you were able to pair the sensors?
    _______________________________________
    Car installation 95% [■■■■■■■■■■■■■■■■■■■]
    Current project: Parking sensor USB interface
  4. #284
    Maximum Bitrate S4Per's Avatar
    Jan 2004
    Seattle, WA
    Thanks much
  5. #285
    Aug 2005
    Italy
    Quote Originally Posted by FMode View Post
    Those values are the last data received from the sensors, and they come from the internal E2PROM of the PIC.
    After programming the PIC, I make a small test to be sure that it works as expected, but before to ship it, I erase always the data stored during the test in the internal E2PROM.
    However you can try to erase again all the data stored in the PIC yourself and then perform again the learning procedure.
    This is the procedure:
    Connect the PIC to an USB port of your PC and start the new program (TPMS Doctor).
    Press and hold on the shift button on your keyboard then clik on my avatar in the bottom left hand side of the window, two new buttons will appear.
    The firs button (Master Reset) completely erase all data stored in the PIC memory (sensor IDs and data received), the second one (Data Reset) erase only the data received (pressure, temperature, etc) but not the learned sensor IDs.
  6. #286
    Feb 2006
    Yep, I made a custom pressure chamber from PVC piping, and end-caps, and use a small compressor to get the pressure to around 2bar (28psi/200kpa), and just tested one sensor, which worked very well.
    Both pressure (6F=1.775bar) and temp (43=27deg C) displays proper, and battery seems fine too.
    Using this little pressure chamber, I will convert it to use a simple bicycle pump to pressurise it for testing units at home before shipping them
    Thanx again!
  7. #287
    Aug 2005
    Italy
    Thanx again!
    Ahahahaha!! Great invention!
    It is exactly what I would have had to use during the firmware development.
  8. #288
    Feb 2006
    I could have made and shipped you one, but the Federales might think it's intended for something else - rofl.
    But, on a sidenote, I will take my UTE to have the 5 sensors installed, and load the config software on the Carputer as a final test. But very happy so far.
    I am just awaiting beta-release of the CentraFuse plugin Wolfgang is developing over at Fluxmedia.net, then I can go finalize the hardware side of things.
    I still need to make the daughterboard for my uBlox-based deadreckonong GPS, but at least I managed to source the Gyro locally, so that can go ahead to.
    Now to get the Siemens TC35 modem going for the security/tracking side of things.
    Ah well, all in good time
    Talk to you later.
  9. #289
    FLAC WuNgUn's Avatar
    Sep 2007
    Anyone doing development with the Valet system?
    I noticed the 3rd Eye is now $250? Did it come down in price?
  10. #290
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    Valet development is being attempted, results have not been spectacular so far...
    TruckPC - gutted, being used for test setup
    BoatPC - off season - Inelmac screen needs serviced again!
    BlazerPC - last vehicle PC I'll build
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. USB self powered hub, which one
    By htsource in forum General Hardware Discussion
    Last Post: 07-26-2007, 04:31 PM
  3. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  4. USB Earthmate - patch for gpsd support
    By dignome in forum GPS
    Last Post: 04-05-2005, 11:44 AM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
