JUVE..... I got your board today, looks great, very nicely sodered and very very very well packaged, you made sure this thing was safe..... Now I just have to get the 3rd eye kit, im trying to get mine with lyhtspeed, if I can get the kit for $140.00 i'll be super duper happy.
HiJackZX1 w/ The Tobiathin Core PC system!
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
Starting Raspberry Pi multizone project.
I am new to this and has jumped on Brandons offer to put together a kit.
I understand that it is you, Robby, that has done most of the reverse enginering and is also the one that has made the pic code. (Excuse me for not reading all the posts. If I am wrong my intension is not to offend anyone)
However:
I've just been hit bad by PhoCo going into the grave, so I am a bit cousios. Will you make the code available, Robby? What I want is the possibility to make changes in case you do not support it anymore, and also to be able to upgrade if needed.
If you plan to go commercial I think that making code available will make product stronger. Not copied. :-)
Or is the code so simple that code is superstable?
(great work btw)
Hi guys now I have prepared 7 USB kits(USB board with all elements, Programmed PIC & Plastic case)...
Don't worry Bes, it will not happen what happened with PhoCo.
The device has been tested for about a year and half without any problem, then I doubt that it will need a bugfix.
Also, the firmware of the PIC sends to the PC, through the USB port, the raw data received from sensors, so any improvement can be easily done by changing the software that runs on the PC side (that is opensource).
Anyway thanks for appreciating my work![]()
_______________________________________
Car installation 95% [■■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
Sorry if this is a daft question , but here goes.
I have ordered a 5 sensor kit , and 4 extra sensors as i have a set of off roading wheels and tyres.
Have all these sensors got unique codes?
Can they all be programed at once ..and will just work when i swap my wheels over ?
Would i have to get the system to learn each time i swap my wheels over ?
