Page 50 of 113 FirstFirst ... 404142434445464748495051525354555657585960100 ... LastLast
Results 491 to 500 of 1127
Thread: Custom USB tyre pressure monitoring interface
  1. #491
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    Quote Originally Posted by vinzer View Post
    Robby Thank you for your answer. I am electrical engineer, so I opened the receiver and found that the output from the recivers RF goes to R3, thats why I connected the aviable pin on the connector directly to it. And after I checked that R3 is connected to this pin already but thru the resistance which I removed. Anyway I will try once again.
    But still another question - in case if in PIC's memory some other sensor's IDs are programmed should I first clean the PIC's ID memory or Config tool during learning process will do it automaticly ?
    Thank you
    The PIC doesn't store any identical sensor ID, so if you want to pair some new sensors, a memory clean is not need, otherwise you need to reset the PIC memory through TPMS Doctor.
    _______________________________________
    Car installation 95% [■■■■■■■■■■■■■■■■■■■]
    Current project: Parking sensor USB interface
  2. #492
    Variable Bitrate vinzer's Avatar
    Jul 2005
    Montreal, Canada
    Quote Originally Posted by Robby BMW View Post
    Thank you very much for clear answer !
    BMW X5 Carputer Project
    Finished: 85%
    http://www.mp3car.com/vbulletin/show...lots-pics.html
  3. #493
    Variable Bitrate rgarjr's Avatar
    Jan 2008
    Covina, CA
    Well just got my TPMS kit all setup and running, finally. Was glad everything worked fine.
    My carpc worklog
  4. #494
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by rgarjr View Post
    I hope mine goes as smooth....
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  5. #495
    Aug 2005
    Italy
    Glad to be helpful
  6. #496
    FLAC WuNgUn's Avatar
    Sep 2007
    Just finished soldering together my TPMS kit...
    Plugged it in, and it found the device, and installed fine...
    Ran TPMS Doctor, and it says device status online, but with the sensors sitting in a box, are they dormant?
    Do they need a pressure/temp change for it to work?
    It's showing raw data when I plug it in though...
    Hope I didn't bugger it with my soldering!!
    Ok guys, the new software is availabel for the download here.
    Attachment 47742
    Change Log:
    1.00
    - First release.
    1.10
    - Fixed the discrepancy between the pressure detected and the raw data displayed.
    - Fixed a little issue with the detection of the battery level.
    - Improved the description of operating state of sensors.
    1.20
    - Fixed a another issue with the detection of the battery level.
  7. #497
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Did you learn sensors?
  8. #498
    Sep 2007
    Quote Originally Posted by _Dejan_ View Post
    No, they are still in the box (the stems)...
    Do you mean they have to be taught before I cut up the IC board?
    I hope I can "learn" them after soldering the board together (CF plugin?)!
  9. #499
    Jan 2008
    Covina, CA
    The sensors are sleeping when there is not great pressure on them. They wont transmit so you wont see them on the pc. When you mount them on your tires, you can start learning them by decreasing or increasing pressure, following the instructions of the software of course.
    My carpc worklog
  10. #500
    Sep 2007
    Does the TPMS Doctor have the learning feature, or do I have to use the CF plugin?
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. USB self powered hub, which one
    By htsource in forum General Hardware Discussion
    Last Post: 07-26-2007, 04:31 PM
  3. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  4. USB Earthmate - patch for gpsd support
    By dignome in forum GPS
    Last Post: 04-05-2005, 11:44 AM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
