Page 52 of 113 FirstFirst ... 2424344454647484950515253545556575859606162102 ... LastLast
Results 511 to 520 of 1127
Thread: Custom USB tyre pressure monitoring interface
  1. #511
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by rgarjr View Post
    Yeah JP3 is your ground and there's 2 pins. Which method are you gonna use, cutting the receiver part or pin method
    I have cut the board in half.... i couldnt deal with having to run more electrical wires.... So technically jumper 3 isnt really 2 pins, just a ground split into two. Im concerned about jumper 1 though.... there is a small diode or what ever you call it. It says 002 on the diode..... Do I pull this off then soder jumper 1 to both to make it one?
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  2. #512
    Variable Bitrate rgarjr's Avatar
    Jan 2008
    Covina, CA
    MrBean was kind enough to snap some close up shots of the board
    pic
    I think you're talking about that small resistor on there. Yeah just leave that little guy there and solder your pin to the pad of it, nearest the cut.
    My carpc worklog
  3. #513
    Jul 2006
    Quote Originally Posted by HiJackZX1 View Post
    PS: Thanks LYHTSPD, I got the 3rd eye kit in the mail today!!!!!!!!!!
    Nice!
  4. #514
    FLAC WuNgUn's Avatar
    Sep 2007
    I know this is maybe a dumb question, but on the board is jumper 3 supposed to be together? Like soder wise? I noticed in Robby's picture of the board its together.... and the one I recieved from Jueve is also together...... Is this correct? Also what is the easiest way to sepearte what I need from the third eye kit? Aslo when sodering jumper 1, do I have to remove that tiny diode or soder with it on there?
    I wondered the same thing...when I tested it with a meter, it was showing continuity, which concerned me a little! But after looking at the schematic, all was well...
  5. #515
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    JP3 is double to ensure a better mechanical fastening.
    You can remove the small resistor and solder JP1 on both pads like in the picture below:
    _______________________________________
    Car installation 95% [■■■■■■■■■■■■■■■■■■■]
    Current project: Parking sensor USB interface
  6. #516
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    soder
    grrrrrrrrrrrr
    wiki is your friend, it's got an L in it, pronounced SOLD - ER
    I blame Norm and his New Yankee workshop for this, I've heard him soddering so many times.............
    Lez, more widely known as flez1966
  7. #517
    Jul 2007
    Miami
    *slaps LEZ in the back of the head* This isnt english class..... I spelled it the way I say it, lol......
    Anyways, did I have to put the pins through the holes? I really wasnt able to get them through so I simply soldered (are you happy LEZ) them to the board without sticking through the holes. Jumper 1 I soldered to the end of the pad with the resistor, I was really scared of damaging the board. Jumper 2, I simply scrapped the green top layer off then soldered to the copper (was this right). When I insalled it into the PC it said, "New Human Interface Device Installed". So I guess I did it correctly, or will it install even if I did it wrong?
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  8. #518
  9. #519
    Aug 2005
    Italy
  10. #520
    Jul 2006
    I had a hard time getting the J3 header pins through the holes, but eventually I got them through. As long as there are making an electrical connection you should be ok. It may not be as physically strong connection though. I would keep an eye on it and expect to re-solder it at some point.
    What you did with J2 is fine. That is really the only way you can make that connection. I left the resistor on J1 as well on my boards.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. USB self powered hub, which one
    By htsource in forum General Hardware Discussion
    Last Post: 07-26-2007, 04:31 PM
  3. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  4. USB Earthmate - patch for gpsd support
    By dignome in forum GPS
    Last Post: 04-05-2005, 11:44 AM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
