Did anybody get a success to connect WAECO device to PC?
always sinking to the bottom of it............
Lez, more widely known as flez1966
Small question....... Why doesnt the TPMS work when plugged into a powered USB hub, but works when pluggin into a onboard USB port. I notice OBDII scanners have the same issue...... Any explanation?
HiJackZX1 w/ The Tobiathin Core PC system!
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
Starting Raspberry Pi multizone project.
Power and bandwidth could be two of the issues.
Mine is behind 2 7-port hubs and works fine.
My carpc worklog
If i put it on the hub, it does install, but as a diffrent device. If i put it directly, then it will say TPMS reciever, then say human interface device...... The OBDII scanner i decided to buy in serial port form, since i have 4 serial ports..... One for HD, XM, OBDII, and AmpCtrl.
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
Enak, Just wondering if you had anymore of the TPMS kits available? I sent a PM.
Regards
_______________________________________
Car installation 95% [■■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
When I was at the UK meet, Enak was having trouble with his until he took it out of the hub and put it in direct, but he also said he had been having other issues with the devices plugged into that hub.
Confusion Says
All USB hubs are not created equal
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
