Page 63 of 113 FirstFirst ... 13535455565758596061626364656667686970717273 ... LastLast
Results 621 to 630 of 1127
Thread: Custom USB tyre pressure monitoring interface
  1. #621
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    _______________________________________
    Car installation 95% [■■■■■■■■■■■■■■■■■■■]
    Current project: Parking sensor USB interface
  2. #622
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Stockholm, Sweden
    Thanks! Getting clearer :-)
  3. #623
    Jun 2008
    ok cool thanks
  4. #624
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    how much did you pay for your kit? and where did you get it from?
  5. #625
    May 2008
    Bend, OR
    I paid 350US for the 5 sensor kit, would have been 325 but paypal bent me over on the currency conversion.
    I bought the last one from another member here. He may have one 4 sensor kit left based on what he commented before I'm not sure.
    I also just tried moving the sensors a few feet away. The head unit seems to respond faster now. Mayyybe it didn't like them being that close. I've been re running the same tests from a distance and it seems to respond quicker. Weird, but I think i feel confident installing it tomorrow with my new car sneakers
    Robby Do you have any close up pics of where to cut the board? The other tutorial site doesn't have any close up pics of where to cut :/
    I also have a Lynx RF receiver laying around 433.92 MHz, Think it will pick up the tires, I need to get the analyzer you used to see if it's receiving. Might be a way to get rid of cutting the board. Thoughts comments?
  6. #626
    Jul 2007
    2 Robby BMW,
    Hi Robby, if you don't mind I would like to ask you one questions concerning Sensor state in Storage mode .....
    In case of the pressure in the wheel is absent will sensor sent data (low pressure) permanently or it will go in the "sleep" mode if during the long period the pressure is still absent (I am trying to follow exactly your idea, but implement the Car-PC interface for WAECO TMPS) ... LYHTSPD mentioned about it.
    And also the second question about data encoding:
    Is your device using the Differential Manchester encoding that is specified here -> http://en.wikipedia.org/wiki/Differe...ester_encoding
    The 3-nd one if you don't mind :-)
    Why did you decided to use Transistor between Receiver's signal and PIC? Just for inverting or the output signal is not 5V compatible? ( I mean, why didn't you put in this signal direct into PIC)
  7. #627
    Aug 2005
    Italy
    Quote Originally Posted by steven765 View Post
    You can give a look at mrbean_phillip's post, it contains a few detailed pictures of how to do the TPMS setup.
    Theoretically any receiver with the following characteristics could work:
    Frequency: 433.92MHz
    Demodulation: ASK
    RF input sensitivity: < –107dBm
    Bandwidth: > 40 KHz
  8. #628
    Aug 2005
    Italy
    Quote Originally Posted by a__l View Post
    2 Robby BMW,
    Only the sensors manufacturer can answer at this question with certainty, however, for what I was able to see, every time the pressure is below 1.5 bar, the sensor goes back in sleep mode.
    Yes, the device uses a differential Manchester encoding.
    The transistor has the dual function to invert the signal and bring it to 5V, as the output from the receiver is about 3.8V.
  9. #629
    Newbie wiggy's Avatar
    Apr 2007
    Help Needed
    I was wondering if any body can shed some light on some problems im having.
    Firstly i purchased the kit from LYHTSPD ( 5 sensor kit - and 4 additional sensors)
    I am using centrafuse 1.47 with TPMS version 0.5.0.1
    Ok , i started off with a clean pic and tryed pairing the sensors .1 sensor will pair , and if i adjust the pressure in the valve it will move up / down within a reasonable time.
    When i try to pair the second sensor , sometimes it wont other times as soon as i click pair and go to let some air out ..it pairs it's self without me touching the valve (or air)
    Other times it will let me pair 2 , but the pressure readings seem to be the same and they dont change either.
    I have reset the pic many times and tryed again.I have positioned the reciever next to each wheel as i try to learn ( does any one know what distance it will work at).
    It seems each time i try something different happens.
    I have tryed uninstalling TPMS software , re installing , but nothing.
    I have not bothered even trying the second set of wheels yet !! ..all the valves were fitted proffesionally and they are holding air ok.
    The most i got to pair was 3 once , but all the pressure values were reading the same , even though i set them all 10 psi different..
    Any body shed any light on this ...i have a second set of wheels for off roading and i was hoping that a quick set up is all i would have needed when i swap my wheels over ...looks like i will have trouble each time !!!
  10. #630
    Aug 2005
    Italy
    Which software do you use to perform the pairing?
    The CF plugin or my config utility?
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. USB self powered hub, which one
    By htsource in forum General Hardware Discussion
    Last Post: 07-26-2007, 04:31 PM
  3. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  4. USB Earthmate - patch for gpsd support
    By dignome in forum GPS
    Last Post: 04-05-2005, 11:44 AM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
