Page 67 of 113 FirstFirst ... 17575859606162636465666768697071727374757677 ... LastLast
Results 661 to 670 of 1127
Thread: Custom USB tyre pressure monitoring interface
  1. #661
    Apr 2006
    It's alive!!!
    Thank you Robby BMW.
    BTW sensors are sleeping mode. not builded in wheels just testing.
  2. #662
    Newbie wiggy's Avatar
    Apr 2007
    Quote Originally Posted by LYHTSPD View Post
    Wiggy, I did test all of the usb interfaces before I sent them out. I made sure that all sensors could pair with the device, and then did a Master Reset to clear out the sensor ID (I was not sure which tire would end up where on the final installation).
    I did see this happen every once in a while when pairing the sensors. I started to wonder if there was just too much RF traffic from all the sensors, and the receiver PIC could not handle all of it. At that point I would usually just call it a night and come back to it the next day, and it would not have any problems. *shrug*
    Edit: From what mrBean said, was there any changes in the PIC code Robby?
    Sorry ..i didn't mean it to sound that way (about testing the unit)...i do appriciate the hard work you did
    I have been trying to get this to work for about 3 weeks now ...so i think its more of a problem than just letting rest for the night .
    Im posting mine to Robby tommorow so he can check out the pic ..hopefully it will be something easy to rectify.
  3. #663
    Feb 2006
    Melbourne, Australia
    Hey Robby,
    Thanx for your efforts I am in not such a rush, I gave my unit to my friend, and I have the "faulty" one now, but I am sure it will be something small.
    Keep us posted.
    Kind regards,
    Phillip
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
  4. #664
    Jul 2006
    Quote Originally Posted by wiggy View Post
    Oh, don't worry. I was not offended by the comment. I just wanted to let you guys know that I did test them.
    I am curious to find out what Robby finds.
  5. #665
    May 2006
    Belgium
    hope the problem will be easy to solve...
    but we are pretty sure it has something to do with the receiver and not the sensors right?
    coz tuesday i will have my tires replaced, and get the sensors installed.
    hope i will not have to deinstall and reinstall them
    Greetz
    Dj NRG
  6. #666
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    I don't think the problem is related to the sensors, but to be sure, I need to do a complete check to Wiggy's unit.
    I will keep you informed about any progress.
    _______________________________________
    Car installation 95% [■■■■■■■■■■■■■■■■■■■]
    Current project: Parking sensor USB interface
  7. #667
    FLAC WuNgUn's Avatar
    Sep 2007
    I'm having issues with my TPMS...
    Whenever I resume the PC, Windows doesn't recognize the USB device. I have to unplug and plug it back in, then it's reinstalled.
    And having it plugged in seems to kill my audio performance...like it's hogging the PCI bus or something. And this is with it not even reading the sensors!
  8. #668
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by WuNgUn View Post
    Sounds like a similar issue I am having with the PDC version, although it only seems to be on the car PC, it's fine on my laptop, and funnily enough fine on my backup CarPC which uses exactly the same MB.
    It only seems to be the one I want to use it with. (also my Gyration Keyboard suffers from the same problem, but my mini USB keyboad doesn't )
  9. #669
    Jul 2007
    That's my working version of TPMS plugin(WAECO) for CF.
    (Car photo has been take from http://www.mp3car.com/vbulletin/rr-p...on-plugin.html if Robby BMW don't mind. Otherwise I will remove it. That's not for commercial purposes..... ).
  10. #670
    Aug 2005
    Italy
    How do you have connected the interface? Directly to an USB port or trough a HUB?
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. USB self powered hub, which one
    By htsource in forum General Hardware Discussion
    Last Post: 07-26-2007, 04:31 PM
  3. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  4. USB Earthmate - patch for gpsd support
    By dignome in forum GPS
    Last Post: 04-05-2005, 11:44 AM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
