Page 68 of 113 FirstFirst ... 18585960616263646566676869707172737475767778 ... LastLast
Results 671 to 680 of 1127
Thread: Custom USB tyre pressure monitoring interface
  1. #671
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    Quote Originally Posted by a__l View Post
    That's my working version of TPMS plugin(WAECO) for CF.
    (Car photo has been take from http://www.mp3car.com/vbulletin/rr-p...on-plugin.html if Robby BMW don't mind. Otherwise I will remove it. That's not for commercial purposes..... ).
    Feel free to use any image
    _______________________________________
    Car installation 95% [■■■■■■■■■■■■■■■■■■■]
    Current project: Parking sensor USB interface
  2. #672
    Dec 2007
    ohio
    The Standalone TPMS utility link does not work; Nor do the PCB links in post #1. Did the domain go down?
  3. #673
    Constant Bitrate goosey2099's Avatar
    Dec 2004
    Staten Island, NY
    Any News on this??
  4. #674
    FLAC WuNgUn's Avatar
    Sep 2007
    Quote Originally Posted by Robby BMW View Post
    How do you have connected the interface? Directly to an USB port or trough a HUB?
    I've tried both...with pretty much the same results.
    With just the TPMS hooked up, and nothing else, it's okay, but the TPMS seems to load up the system someway when I connect my other USB devices.
    But when I have ALL my USB devices mounted, but no TPMS, the system is also fine...
  5. #675
    Dec 2007
    ohio
    Quote Originally Posted by WuNgUn View Post
    hmm, is anyone else having this problem. I've been compiling the parts for my carpc build and i'll be using a lot of usb devices.
  6. #676
    Aug 2005
    Italy
    Maybe a powered HUB could solve your problem.
  7. #677
    Sep 2007
    My 'hub' is powered off the PCI slot, since it's a PCI to USB adapter...
    Same results with that hub, or the onboard USB ports...
  8. #678
    Sep 2007
    Quote Originally Posted by 96300NAZ View Post
    I know one other person for sure, depending on which PC he uses it on...but he's having the same issues I think.
  9. #679
    Aug 2005
    Italy
    @ wiggy, goosey, Dj-[NRG], mrbean_phillip and all those who have problems performing the "learn" procedure, I've found an issue with the USB buffer that causes an abnormal termination of the procedure.
    The problem has been fixed in the last releases (1.30) of my two programs TPMS Doctor and RRTMS, so please download them, upgrade your systems and let me know if this solve.
    As usually, I recommend everyone to terminate all the programs that have direct access to the TPMS interface, like RoadRunner, Centrafuse and TPMS Doctor, before to launch RRTMS Config and to perform the "learnig" procedure.
  10. #680
    Sep 2007
    Is there an updated Centrafuse plugin too?
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. USB self powered hub, which one
    By htsource in forum General Hardware Discussion
    Last Post: 07-26-2007, 04:31 PM
  3. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  4. USB Earthmate - patch for gpsd support
    By dignome in forum GPS
    Last Post: 04-05-2005, 11:44 AM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
