Page 69 of 113 FirstFirst ... 19596061626364656667686970717273747576777879 ... LastLast
Results 681 to 690 of 1127
Thread: Custom USB tyre pressure monitoring interface
  1. #681
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    As the Cetrafuse plugin has been developed by Wolfgang, I don't know if it has the same bug, but using the new version of my Config Tool, you should be able to perform the "learning" procedure without problems.
    _______________________________________
    Car installation 95% [■■■■■■■■■■■■■■■■■■■]
    Current project: Parking sensor USB interface
  2. #682
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Quote Originally Posted by WuNgUn View Post
    Is there an updated Centrafuse plugin too?
    Im send to Wolfgang email with new source and tell him that some guys have problem in learning methode...
  3. #683
    Aug 2005
    Italy
    Thank you Dejan.
    Please tell to him to feel free to contact me for any questions.
  4. #684
    May 2006
    Belgium
    Thx Robby,
    will try that as soon as possible.
    I'll let you know if it works
    Greetz
    Dj NRG
  5. #685
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Quote Originally Posted by Enforcer View Post
    Sounds like a similar issue I am having with the PDC version, although it only seems to be on the car PC, it's fine on my laptop, and funnily enough fine on my backup CarPC which uses exactly the same MB.
    It only seems to be the one I want to use it with. (also my Gyration Keyboard suffers from the same problem, but my mini USB keyboad doesn't )
    That doesn't sound good,are you still having the issue?
    Robby's found issue with the tpms software,is it likely the same bug is affecting the pdc setup?
    P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
  6. #686
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I doubt it, the PDC's actually work, it's just my board/software is struggling to hook up to the box.
    Thing is, it's only the carputer PC, my laptop is fine, and another PC which has the same board as the carputer is fine, although it doesn't have exactly the same XP install. I need to get a 2.5" drive in there and ghost the carputer one, so I can do some parallel testing.
  7. #687
    FLAC WuNgUn's Avatar
    Sep 2007
    Quote Originally Posted by Griff1 View Post
    I'm having this problem, without even running the software...just having the thing plugged in does it...
  8. #688
    Nov 2007
    Sydney, Oz
    I also am now having a similar problem with RR. It would appear that several tyres are picking up the same sender unit, as the Hex codes showing in the Doctor, are all the same.
    I dont have to adjust the tyre pressures after resetting the doctor, as all I do is go into training mode, and the tyres just get configured.
  9. #689
    Aug 2005
    Italy
    Quote Originally Posted by allypally View Post
    This bug has been fixed, download the new releases of TPMS Doctor and RRTMS.
  10. #690
    Nov 2004
    Just to let anyone who is still looking for a 3rd eye TPMS know, Viva Performance has them in stock again: http://www.vivaperformance.com/catal...roducts_id=444
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. USB self powered hub, which one
    By htsource in forum General Hardware Discussion
    Last Post: 07-26-2007, 04:31 PM
  3. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  4. USB Earthmate - patch for gpsd support
    By dignome in forum GPS
    Last Post: 04-05-2005, 11:44 AM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
