Page 70 of 113 FirstFirst ... 20606162636465666768697071727374757677787980 ... LastLast
Results 691 to 700 of 1127
Thread: Custom USB tyre pressure monitoring interface
  1. #691
    Jul 2006
    Quote Originally Posted by Robby BMW View Post
    @ wiggy, goosey, Dj-[NRG], mrbean_phillip and all those who have problems performing the "learn" procedure, I've found an issue with the USB buffer that causes an abnormal termination of the procedure.
    The problem has been fixed in the last releases (1.30) of my two programs TPMS Doctor and RRTMS, so please download them, upgrade your systems and let me know if this solve.
    As usually, I recommend everyone to terminate all the programs that have direct access to the TPMS interface, like RoadRunner, Centrafuse and TPMS Doctor, before to launch RRTMS Config and to perform the "learnig" procedure.
    I am glad to hear that you may have found the culprit. Thanks again for all your hard work on this Robby!
  2. #692
    Lok
    Lok is offline
    VENDOR - Portal Media Lok's Avatar
    Feb 2008
    Quote Originally Posted by juve021 View Post
    Just to let anyone who is still looking for a 3rd eye TPMS know, Viva Performance has them in stock again: http://www.vivaperformance.com/catal...roducts_id=444
    Hey guys,
    If you are looking for a kit we are working on one right now. I think I posted this link somewhere in the thread but i know there's like a million posts now so here it is again if you can't find it. (http://www.portalmediapc.com/forums/showthread.php?t=10) Its cheaper than the 3rd eye (less than $200) and you don't have to hack together a system as it will be all on a single circuit board (we are going surface mount on the components as well to speed up production and reduce costs). I will be selling the sensors too as part of a complete USB kit (I am getting them directly from malayasia). Also Robby is going to help me with getting the chips programmed so you don't have to worry about having a different unit than the rest of us as it will work exactly the same. Right now we are working on getting a waiting list together for the initial run(only 8 spots are left) and those buyers will get the units at a bargan price, but after that MP3car will most likely be handling the online sales and the price will be significantly higher.
  3. #693
    Jul 2006
    Quote Originally Posted by Lok View Post
    Hey guys,
    Sounds good Lok! Thanks for taking this thing by the reigns and getting it moving in the right direction.
  4. #694
    Dec 2006
    Excellent Lok...The completely integrated USB kit would be very welcomed. You have a PM.
    The 3rd eye TPMS unit was way too over-priced. TPMS kits from other vendors are available for $60-$100 and offering more or less the same functionality. But since the USB TPMS PIC was based on the 3rd Eye kit, we were pretty much stuck with it.
  5. #695
    Newbie wiggy's Avatar
    Apr 2007
    Quote Originally Posted by LYHTSPD View Post
    I second that
  6. #696
    Jul 2006
    Quote Originally Posted by wiggy View Post
    I second that
    Did Robby's update fix your issue Wiggy?
  7. #697
    Apr 2007
    I have not got the usb board back yet ( on its way as we speak) , but as soon as it arrives i shall try the new software ...fingers crossed
  8. #698
    Lok
    Lok is offline
    Feb 2008
    I am having problems with the learning procedure as well using Dejans board and a hacked 3rd eye...I know Robby has updated the Doctor and the RRTMS but I am using CF however and I was wondering if there was a way around this issue without me having to load up RR...
  9. #699
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Hi,
    With new TPMS doctor work ok? Im tell that Im report this problem to Wolfgang(He develope plugin for CF) and he answer me that he will look in code...
  10. #700
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Stockholm, Sweden
    I have just installed the 3'd eye sensors on my wheels.
    [media]http://web.comhem.se/mulle4/tpms_sensor.jpg[/media]
    Quality is not impressive. I manage to destroy one sensor.
    [media]http://web.comhem.se/mulle4/brokensensor.jpg[/media]
    The instruction manual was not specific on how to place washers. I did not use my sense, and placed alu washer on wrong side first as I tried to do it as I could see from picture in manual. Alu washer goes on the outside...
    The aluminium nuts also loose shape once fitted, and it is a bit difficult to refit the tyres. At least the low profile 18" I've got on my E46 BMW.
    The washer for the insex nut at the sensor also gets deform once mounted.
    The pin for holding the pin still when fastening the nut did not fit 3 of the 5 sensors I tried.
    In short, you get one chance to do it right and you cannot refit a sensor once used.
    A bit disapointed of the poor quality and I have not yet got to the point of learning sensors and receiving data...
    One question: Without looking into the spec of the pic the learning problem must be in the writing/erasing of EEProm/flash in the pic. Or possibly some powersupply issue as write cycles might require a second voltage supply. What do you think? Is there a new pic sw in the pipe?
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. USB self powered hub, which one
    By htsource in forum General Hardware Discussion
    Last Post: 07-26-2007, 04:31 PM
  3. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  4. USB Earthmate - patch for gpsd support
    By dignome in forum GPS
    Last Post: 04-05-2005, 11:44 AM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
