Page 71 of 113 FirstFirst ... 21616263646566676869707172737475767778798081 ... LastLast
Results 701 to 710 of 1127
Thread: Custom USB tyre pressure monitoring interface
  1. #701
    Lok
    Lok is offline
    VENDOR - Portal Media Lok's Avatar
    Feb 2008
    I had my sensors professionally installed at Discount Tire Co. They had no problems in the installation but I was told that if I were to hit a large pothole I would most likely break a sensor (maybe all of them). This was due to the fact that I have ultra low profile tires and also because the sensors didn't sit flat against the Rim (the way my enkies are designed they couldn't) they actually were sticking out.
    By the way I don't think anyone answered this yet but is there a way to do the learning procedure without CF or RR?
  2. #702
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Stockholm, Sweden
    Yes, I had a pro break my sensor too :-)
    [media]http://web.comhem.se/mulle4/tpms_wheel.jpg[/media]
    €100 including stabilizing.
  3. #703
    Dec 2006
    Quote Originally Posted by bes51659 View Post
    On a positive note, we got to know what is inside the sensor
    Do you have detailed snapshots of the sensor board...I'm curious to know the transmitter chipset.
  4. #704
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    As I said in this post, it is possible to perform the learning procedure with the configuration tool provided with the RoadRunner plugin, even if you use Centrafuse.
    There isn't need to install RoadRunner, just download the last release of RRTMS plugin from here end extract the program "RRTMS Config.exe".
    _______________________________________
    Car installation 95% [■■■■■■■■■■■■■■■■■■■]
    Current project: Parking sensor USB interface
  5. #705
    Aug 2005
    Italy
    One question: Without looking into the spec of the pic the learning problem must be in the writing/erasing of EEProm/flash in the pic. Or possibly some powersupply issue as write cycles might require a second voltage supply. What do you think? Is there a new pic sw in the pipe?
    No, the problem was due to a bug in the management of the USB input buffer.
    Maybe you have confused the program flash memory, that require a second voltage supply to be programmed with the internal EEPROM, that can be written and erased directly by the program.
  6. #706
    FLAC WuNgUn's Avatar
    Sep 2007
    Quote Originally Posted by Robby BMW View Post
    And once the RRTMSconfig is setup, the Centrafuse plugin has access to this config info, and no further setup is needed (for CF)?
  7. #707
    Sep 2007
    This input buffer issue is not related to the audio stuttering issues some of us are having with the TPMS plugged into the USB port?
  8. #708
    Aug 2005
    Italy
    Quote Originally Posted by WuNgUn View Post
    Don't pay attention to the other settings, just use the "Learn" buttons to pair the sensors.
  9. #709
    Aug 2005
    Italy
    Does the problem occur when the TPMS is simply plugged into the USB port or only when the plugin is running?
  10. #710
    Sep 2007
    Just having it plugged into the USB port...
    I haven't tried running it yet (still on the bench)
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. USB self powered hub, which one
    By htsource in forum General Hardware Discussion
    Last Post: 07-26-2007, 04:31 PM
  3. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  4. USB Earthmate - patch for gpsd support
    By dignome in forum GPS
    Last Post: 04-05-2005, 11:44 AM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
