Page 75 of 118 FirstFirst ... 25656667686970717273747576777879808182838485 ... LastLast
Results 741 to 750 of 1178
Thread: Custom USB tyre pressure monitoring interface
  1. #741
    May 2008
    Great thanks Robbie.
  2. #742
    May 2008
    Thank you to all who helped........... all 3 systems are working now and I have another 4 on the way from Dejan so I know what I'm doing now........
    Ironically it seems that keeping the receiver well over 1 metre away from the sensors gave the best results....... too close and it seems to get confused.
    Thanks again to all who gave assistance.
  3. #743
    Aug 2008
    did anything come of this, are the board available to buy? as i have no idea what to do very interested in the system but dont have required skills to solder/make board ect
  4. #744
    Lok
    Lok is offline
    VENDOR - Portal Media Lok's Avatar
    Feb 2008
    New TPMS PCB
    Hey guys, here are some pics of the PCB we are working on. I will have pics of the whole production process shortly for those of you that are interested in the PCB assembly production process.
  5. #745
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Quote Originally Posted by Lok View Post
    Wow.
    I'd decided against adding this feature as it wasn't very cost effective but i think now its cheaper and an all in 1 kit i'll reconsider.
    P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
  6. #746
    Jul 2006
    Lok, I am having trouble seeing your pictures. Anyone else having issues?
  7. #747
    Dec 2006
    India
    Good panelisation... How many layers is the board?
    Quote Originally Posted by LYHTSPD View Post
    No issues seeing the panelised PCB snapshots.
  8. #748
    Dec 2006
    India
    Another question.
    I see that the PIC is an SMD now.
    Nice choice from a production point of view, but how is the fimware upgrade planned if Robby releases a firmware fix some time down the lane? Can this be done via USB?
  9. #749
    Lok
    Lok is offline
    Feb 2008
    Quote Originally Posted by DigitalVampire View Post
    Another question.
    There is a 6 pin header used for programming and reprogamming if needed, only problem is that you will most likely have to send them in if they need to be reprogrammed as I am sure most of you don't have a progammer lying around and also because Robby would like to have control over the firmware. I don't think the current design will support reprogamming via USB but you have to ask Robby about that. Oh and its just a double sided board, there isn't much on the back though.
    LYHTSPD if you can't see the pictures here then check either Centrafuse forums or Portal Media forums as I have them posted there as well.
  10. #750
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    have you got an idea on the price including sensors yet?
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 10:30 PM
  2. USB self powered hub, which one
    By htsource in forum General Hardware Discussion
    Last Post: 07-26-2007, 03:31 PM
  3. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 03:24 PM
  4. USB Earthmate - patch for gpsd support
    By dignome in forum GPS
    Last Post: 04-05-2005, 10:44 AM
  5. Replies: 4
    Last Post: 04-06-2004, 09:52 AM
