Page 77 of 120 FirstFirst ... 27676869707172737475767778798081828384858687 ... LastLast
Results 761 to 770 of 1194
Thread: Custom USB tyre pressure monitoring interface
  1. #761
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Vasastaden, Stockholms Län, Sweden, Sweden
    rgarjr:
    I might be wrong, but it looks to me that the entire external antenna has the shield still on.
    Not as shown on this drawing
  2. #762
    FLAC WuNgUn's Avatar
    Sep 2007
    I tried learning mine for the first time...from Centrafuse...
    No go...nothing.
    Also, everytime I restart the PC, I lose the TPMS device. I have to physically unplug and plug it back in! Major PITA...
    Gonna try TPMS Doctor I guess...
  3. #763
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by WuNgUn View Post
    No go...nothing.
    I had this issue when plugging the TPMS into a hub. I had to use a onboard port. Also if you use X-Port for you GPS, it has the option to virtually unplug other devices also. i do it for the GPS, and thinking about doing it with my Sprint card, it freezes sometimes too.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  4. #764
    Sep 2007
    Quote Originally Posted by HiJackZX1 View Post
    I need to look into the X-port thing...
    But I STILL can't get the ******* thing to learn! I make sure it's connected, the plugin says it's 'ok', I go into settings, pick the sensor and tire and learn, it's 'waiting', I go and deflate the closest tire (almost flat!!) and it doesn't 'see' diddly-squat...
    I'm getting very frustrated...especially considering the time and money I put into this!
  5. #765
    Jul 2007
    Miami
    OMFG, you sound like me when I get ****ed, lol. You are really scaring me, because although I have had the TMPS for awhile (5 months i think), I havent installed them into the tires yet.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  6. #766
    May 2008
    I found at first that I seemed to have similar issues, but in the end all I did was put all other sensors I wasn't pairing up with the controller in the other room, far enough away that there was no chance of issues. I know they're not nessecarily meant to be sending info, but I did this regardless.
    Then I just made sure the sensors were well away from the controller and was very patient in the learning process, as someone else mentioned, it seemed like sometimes the TPMS doctor and the other applications get a bit grumpy. I basically got them to learn quite easily in the end and once they were done I unplugged the USB module and then ran the RRTPMS plugin and tested, all seemed well so I then loaded the CF plugin and also worked well.........
    I have to admit the process isn't fullproof, but if you keep the sensors well away from the controller (2metres) then it seems to help, when I had them too close I was getting no joy.
  7. #767
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    HiJackZX1 did you try learn it outside CF? Maybe are in CF buffer problem...
  8. #768
    Apr 2006
    Sydney, Australia
    Hey Lok,
    Can u put me on the list?
    Once I get my PSU fix, i want one, now that there's a full kit
    PM me with more details please, thanks.
  9. #769
    Sep 2007
    The sensors are already in the car...
    How do you do the 'learn' with TPMS Doctor?
  10. #770
    Lok
    Lok is offline
    VENDOR - Portal Media Lok's Avatar
    Feb 2008
    Have you tried using RRTMS 1.40 to learn the sensors? You don't have to use the CF plug-in to program, in my experience it is still quite buggy. RRTMS works much better (not to mention it has had many more revisions) when it comes to learning sensors. Once the sensors are learned the data is stored to EEPROM on the board itself so you can see the data on CF after they are learned, you can even switch computers and it should still work identically. Also another thing to look out for is distance. Too close is no good and being to far away doesn't do much good either, I would say about 3-4 feet (1 meter) has been the sweet spot during my testing but I have had the sensor work from as far as 10 meters (outside, open field, using a pesticide sprayer). Also when I tried to put the reciever right next to the sensor when learning the sensor did not want to learn 9 out of 10 times. Also if you haven't already mounted the sensors then it might be best to purchase an inexpensive pesticide sprayer to do the learning so you don't have to keep inflating and deflating your tires. I hope this helps solve some issues...
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 10:30 PM
  2. USB self powered hub, which one
    By htsource in forum General Hardware Discussion
    Last Post: 07-26-2007, 03:31 PM
  3. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 03:24 PM
  4. USB Earthmate - patch for gpsd support
    By dignome in forum GPS
    Last Post: 04-05-2005, 10:44 AM
  5. Replies: 4
    Last Post: 04-06-2004, 09:52 AM
