Page 91 of 122 FirstFirst ... 4181828384858687888990919293949596979899100101 ... LastLast
Results 901 to 910 of 1211
Thread: Custom USB tyre pressure monitoring interface
  1. #901
    FLAC WuNgUn's Avatar
    Sep 2007
    Hey Robby..got my 2.0 chip this week...Thanks again!!
    The original will be coming your way Monday.
    Thanks again...
  2. #902
    Jan 2008
    Southern Calif
    Woah that was fast... Let us know how the new FW works out on the learning of the sensors.
  3. #903
    Lok
    Lok is offline
    VENDOR - Portal Media Lok's Avatar
    Feb 2008
    One more picture! Here is the Old version sitting next to the New version. See if you can spot all 10 differences (just joking around ).
  4. #904
    Jun 2008
    Minsk, Belarus, Belarus
    Greetings!
    I wish to buy to myself the complete set of the second version, on 4 wheels how it to make?
  5. #905
  6. #906
    Variable Bitrate vinzer's Avatar
    Jul 2005
    Montreal, Canada
    _Dejan_,
    Thank you very much, I just got my 2.0 version PIC from you. Tommorow will be the day to give it a try !
    BMW X5 Carputer Project
    Finished: 85%
    http://www.mp3car.com/vbulletin/show...lots-pics.html
  7. #907
    Nov 2004
    St Louis
    I was waiting for the beta test forum, but I guess this will have to do. I am now the proud user of two TPMS systems - thanks LOK for your outstanding customer service (let's hope my experience was unique). So far no leaks, no breaks, no problems. System 1 was a Third Eye with Robbys mod from LYHTSPD; the second was a complete system from LOK via the initial waiting list.
    What makes this unique is both are permanently installed in two different vehicles, but only one PC. I have docking stations in each car and was initially concerned that the learning process on the second would erase the saved sensors from the first - but it didn't! My tablet already has a script run on startup that identifies which car its in and sets some parameters, so now I need to add the rrtms.ini cause the pressures and alerts are different for each car.
    But the systems are working flawlessly: my temps are all within 4 degrees; pressure is dead on; alerts fire as programmed and reset immediately; learning was smooth and error free; and the antennas are just right for my cars.
    One technique I would like to pass on to the group - If you can, work it out with the tire shop to let you learn the sensors as they are being installed. My first set I tried to do the learn process after they were installed - I rushed it and had problems. On the last set, I hit the learn button as soon as the tire was popped back on. The mechanic aired it up and as it lost pressure while he inserted the valve the learning process completed. The interval between tires is just right so the process has the necessary time to normalize the previous sensor and the distance between the car on the lift and the tire is short and unobstructed. So when the mechanic finished the last tire, I was ready to assist him in setting the exact tire pressures I wanted. (My guy laughed when I told him I wanted all four tires within 1/2 pound, but he did better - they're within .2lbs.) By the time I paid and got my keys, even the temps were within 4 degrees and I was all set.
  8. #908
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Just wanted to let you guys know that I have a extra board and pic chip laying around. My dog smashed it and I was never able to get it to work again. I went ahead and bought one of LOK's kits, which are very well built by the way. Who ever wants to try to save my old one can have it, just pay for shipping.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  9. #909
    Constant Bitrate lacning74's Avatar
    Apr 2008
    Quote Originally Posted by HiJackZX1 View Post
    bummer. cool if he swallowed the sensors and you could measure is flatulence, though. tpms dog.
  10. #910
    Jul 2005
    Montreal, Canada
    I have a question here. Is there any STAND ALONE software for TPMS available ? I know there is plugin for RR and for Centrafuse and both are great ones, however they may work only with in the frontend software.
    For example TPMS Doctor is good as a stand alone application but it can not give a sound warnings while pressure or temp is out of the range. The reason why I am looking for it is simple: I am under SD2 and there is no TPMS plugin available for it at the moment. I do not have enoufgh skills to write one so I want to run some TPMS standalone application on background and have warnings comming on if something goes wrong.
    Please help with the suggestion on this. Thank you
    Finished: 85%
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. USB self powered hub, which one
    By htsource in forum General Hardware Discussion
    Last Post: 07-26-2007, 04:31 PM
  3. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  4. USB Earthmate - patch for gpsd support
    By dignome in forum GPS
    Last Post: 04-05-2005, 11:44 AM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
