Page 94 of 122 FirstFirst ... 4484858687888990919293949596979899100101102103104 ... LastLast
Results 931 to 940 of 1211
Thread: Custom USB tyre pressure monitoring interface
  1. #931
    FLAC WuNgUn's Avatar
    Sep 2007
    Speaking of which, my V1 kit stems are a little 'iffy' as well...I had one that spun the entire stem when trying to undo the cap! I was worried the sensor might pop off on the inside.
    Also, filling the tires...some filler necks just can't reach properly, and the air leaks out around the stem. kinda weird...
    I think the next time I have my tires off, I'm just going to use double sided tape and mount the sensors off the stems...just put them on a flat surface on the perimeter of the rims...
    Then go back to normal, rubber stems...
  2. #932
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by WuNgUn View Post
    I had/have this issue, two of my tyres are perfect but the other two just aren't long enough, so I now use little plastic extensions to pump the tyres up.
    The other two also seem to lose pressure over 10 days although I have found one is screwed (ie I have a screw in the tyre)
    Do the bits in the middle rotate to tighten?
  3. #933
    Low Bitrate BCasey's Avatar
    Sep 2008
    hey guys,
    sorry if this is answered in this thread already, if the answer is yes ill go back raed the whole thing.
    Is it possible to use this system with the TMPS sensors already equipped in my tires from the factory or does the sensors in the tires need to be replaced with these ones in order for this to work?
  4. #934
    Constant Bitrate lacning74's Avatar
    Apr 2008
    This bracket seems like a neat solution if you don't trust tape:
    http://g35driver.com/forums/3265529-post1.html
    http://www.tpmssolution.com/
    Seems more elegant than using a metal strap.
    This leaking valve issue is keeping me from getting Lok's TPMS kit for now.
  5. #935
    Dec 2006
    India
    Has anyone figured out why the valve stem issue is popping up now?
    Did the valve stem design change recently?
    Did anyone face this issue with the original 3rd eye kits?
  6. #936
    May 2008
    I used to have a Smartire system before I changed to this system and they attached their sensors with straps like this http://cgi.ebay.com/Band-It-Scru-Sea...424206005r2208
    So I kept with the same idea. I know not everyone will have enough of a flat spot inside their wheels to allow to position the sensors, but I did so I just strapped them to the rims...... no worries about the valve stems at all then, just used the original ones.
    The supplied stems wouldn't have worked well on my rims either so that was another reason to find another solution.
  7. #937
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by f1racr View Post
    OMFG, I think I just busted in my pants..... Your car is f$%king beautiful. Also rare!!!!!!!!!!
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  8. #938
    Jul 2006
    Quote Originally Posted by lacning74 View Post
    THAT is slick. I like that idea a lot.
  9. #939
    Lok
    Lok is offline
    VENDOR - Portal Media Lok's Avatar
    Feb 2008
    Thanks for the info guys this will really help me out. I am going to call Iforged and get one of these on order. Maybe I can talk to my metal fabricator into designing a bracket that is specific to our sensor and won't require use of the valve stem at all. We can just connect the sensor directly to the bracket which will be fixed to the exisiting valve stem.
    I have a question for you guys, I know it may sound stupid but I don't know too much about tires and how they are mounted, do all tube-less tires have removable valve stems? Basically I want to know if this bracket idea will work on all rims including factory rims.
  10. #940
    Jul 2007
    Miami
    Quote Originally Posted by Lok View Post
    OH wait, so you dont really need the valves? If not they sell other sensors that have a large metal band and you actually secure the sensor to the middle of the rim.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. USB self powered hub, which one
    By htsource in forum General Hardware Discussion
    Last Post: 07-26-2007, 04:31 PM
  3. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  4. USB Earthmate - patch for gpsd support
    By dignome in forum GPS
    Last Post: 04-05-2005, 11:44 AM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
