Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 63
Thread: USB TPMS Pictures of Working Setups
  1. #21
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by GizmoQ View Post
    Did you run TPMS Doctor.exe and it recognized sensor 1? When you learned it did the banner go away? If so, just wait a day for all the sensors to recycle to normal mode. Then just relearn the one sensor by deflating it, once the banner goes away pump it back up and wait 15-30 minutes for it to return to normal mode. Should work right from then on.
    Otherwise you got what we call a "lazy" sensor. Moving the receiver to d different location sometimes fixes it, but no one has a definitive solution.
    yes it recognizes it, and it seems to get the very first reading from the sensor each time. but 90% of the readings after that miss. I've moved the receiver all over the car to no avail. Lazy sensor indeed. Spose when i have some cash i'll swap the spare sensor with sensor 1
    Live mp3Car Facebook Chat
  2. #22
    Variable Bitrate debugger's Avatar
    Mar 2006
    CA
    Does ELM scan software pull data from factory installed TPMS? Can these be used with factory equipment?
  3. #23
    Lok
    Lok is offline
    VENDOR - Portal Media Lok's Avatar
    Feb 2008
    Quote Originally Posted by Sonicxtacy02 View Post
    Shoot me an email if you want to swap that sensor I recieved a fresh batch this week, all i ask is that you pay for shipping...
  4. #24
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by Lok View Post
    Thank you for the offer but its still in the tire. I was just going to swap it with the spare valve because my spare is buried beneath all my car pc stuff anyway. If for whatever reason the spare valve has a problem i may take you up on it. Thanks for the gesture though good businessman
  5. #25
    riv
    riv is offline
    Dec 2009
    Re: Usb tpms
    A few question, if anyone know the answers regarding USB TPMS kit:
    1. How long the batteries on the sensors are last?
    2. Could this kit support more then 4 sensors at the same time? Say 6 or 8?
  6. #26
    Feb 2006
    Melbourne, Australia
    @ Riv: Batteries will last something like 5 years. At this point in time, I do believe the software limitation is 5 sensors - either that, or 9 sensors, can't remember now. Hardware should be capable anyway of supporting up to 9 sensors, but we will need new firmware for this - which Robby may or may not do.....
    Anyway, herewith a few shots showing how I mounted Alok's TPMS receiver in my M350 Minibox case(mini-itx) - please note I've replaced the stockie antenna with something a little better, and it works fine within the passenger cabin. I have also desoldered the orginal TPMS USB socket, and soldered a cable, which connects via to a default header-block to one of the internal USB connectors to the Zotac motherboard.
    NONE OF THIS is visible once the default M350 plastic bezel is attached the standard way Very nice, and compact!
    and
    and a last one:
    Now, all we need is either Alok or Wolfgang to redo the TPMS plugin for CF30 :flowers:
    Hope this is of some help to someone.
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
  7. #27
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by mrbean_phillip View Post
    i'm ready to pay someone some cash to get this accomplished!
  8. #28
  9. #29
    Woodbridge, VA
    Blog Entries
    32
    i attempted to do it... but converting from cf2 to cf3 AND converting from c# to vb.net became quite the chore. Couple that with the fact i have no skins NOR do i know what skins are required because i cant install the CF2 version without CF2 installed. Needless to say i'm kinda lost
  10. #30
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Well I now have a separate HD for my laptop which I have installed CF3 on, so I am in the process of converting my CF2 plugins over to CF3.
    Maybe when I get them done I will look at the TPMS one.
    Or if you want I can get you the TPMS skins for CF2.
  1. HFP for Linux Bluetooth Hands Free
    By samr7 in forum Linux
    Last Post: 02-06-2012, 06:21 PM
  2. USB recognition issues
    By Brycestro in forum Software & Software Development
    Last Post: 10-25-2007, 11:35 PM
  3. USB Keyboard not working after hibernation
    By XxAndyxX in forum General Hardware Discussion
    Last Post: 11-11-2005, 04:38 PM
  4. USB Hub not working after coming out of hibernation
    By volum3rider in forum Input Devices
    Last Post: 09-11-2005, 01:07 PM
  5. usb mouse stops working
    By corsamel in forum General Hardware Discussion
    Last Post: 10-18-2003, 06:53 AM
