They also have cases that are built for the car!
Mobile-PC
OPUS Solutions Mobile-PC is designed specifically for ATX motherboards to be used in an automotive
environment. This Product brings a new dimension to your PC’s mobility. Just get in your vehicle and
start the engine; your PC is ready to go. When you switch off the ignition the PC can go into shut
down, standby or hibernate modes automatically, no switch to fiddle or fuss.
The Mobile-PC can accommodate a full ATX motherboard. The Mobile-PC can enjoy a wide selection of
hardware and software that are available for a PC platform. Thus, the Mobil-PC is an ideal choice for a
fully expandable computer at a reasonable system cost. The system can be upgraded, when required,
without loosing all the initial investment, unlike laptops.
The Mobile-PC is constructed with a heavy gauge aluminum sheet metal. The case is ruggedly built to
with stand the shock and vibration that are encountered in a tough mobile environment. The case is
designed with easy accessibility to I/Os, cables and CD/ DVD ROM Drive or removable Hard Drive.
The I/O connectors and cables are covered to protect it from accidental damage. The Mobile-PC has a
security lock to prevent unauthorized access inside the unit. The hard drive is protected from shock
and vibration by a specially designed isolation mount. A daughter card retain bracket is designed in
to prevent Cards from sliding out during shock and vibration.
The Mobile-PCs DC-DC Power supply has a micro-controller that controls and monitors various
functions of the power supply operation. It monitors automobile battery voltage to protect against deep
discharge. The Ignition lead is monitored to start the Mobile-PC when the ignition is turned on and to
implement a safe shutdown procedure. It controls and monitors motherboard signals to provide
smooth power-up and power down sequences. In addition, it also responds to shut down, stand-by
and hibernate modes. The power supply can be programmed to shut down the PC after a delay of up
to one hour. The power supply outputs are monitored to assure proper PC operation. A green LED
indicator in the power supply continually reports the power system status and health. It is also used
for troubleshooting.
There are features that are built-in for trouble free and safe PC operation. The input power is protected
against transients, load dumps and double battery during jumpstarts. PC does not reboot during
engine start or cranking.
Input: 12V 24V
Normal input voltage range: 7V to 18V DC 18V to 36V DC
Low battery shutdown voltage: 11.7 Volts ±. 75V
Low battery detection duration: 10 Sec.
Input current drain:
Power down/ Standby mode: 0.025 A
Output: 160W Ripple Regulation
+3.3V: 10A max, 15A pk, 50mV p-p max 2%
+5 V: 10 A max, 15A pk 50mV p-p max 2%
+12 V: 5 A max, 6.5 A pk 50mV p-p max 2%
-12 V: 0.2 A max, .4 A pk, 150mV p-p max 10%
5 V standby: 1 A max, 1.2 A pk 50mV p-p max 2%
Power supply efficiency > 90% at optimum loads
MTBF: 150,000 hrs
Operating Temperature Range: -25 °C to 70 °C
Ignition/ Power switch current drain: <10 mA
Input Fuse: 20A ATO replaceable (Automotive blade fuse)
Input Power Mating connector: Plug: AMP P/N: 350766-1
Crimps: Amp P/N: 640310-3 and 350919-3
Output Power Connectors: 20 pin ATX Mother power connector, cable length 240 mm long
8 pin Drive power connector to 3 HDD and 1 FDD power connectors
2 pin ATX power Switch connector, cable length 420mm
External Dimensions: 100mm(W) x 125mm (D) x 63.5mm (H)
3.94” (W) x 4.92” (D) x 2.5” (H)
Mobile-PC Case Specification:
External Dimensions: 13" W x 15.5"D x 5.6"H.
Motherboard: Full ATX mother board compatible
Expansion: 7 slots.
Drives mounts: 1 x 3.5” Hard drive mount with shock and vibration isolation.
1x 5.25” Bay front accessible ( CD-ROM, DVD ROM, CD-RW or removable HDD)
Security Lock: 4 pin cam lock
Mounting:
Bottom plate mounting: Four holes are located on the bottom corners of the chassis for # 8 screws.
Other mounting options: Mobile-PC Shock mount kit. (Adds 2” to the height of the Mobile-PC)
Floor mount bracket kit
Slide rail mount kit
Hard drive heater and controller option Call for detail
Hard Drive heater trigger temperature Below 8deg C. +- 3deg. Computer will not be turned below trigger temp.
Specifications subject to change without notice
Ordering Information
Part Number Description
MPC-ATX-CPS-A Mobile-PC Case and Power supply only
MPC-ATX-xx Custom configuration available, Call Sales for detail
OPUS Solutions. Inc. Email: sales@opussolutions.info
6 Reef Tel: 949-388-7623
Laguna Niguel, CA 92677 Fax: 949-388-7628
www.opussolutions.com
LinkBack URL
About LinkBacks
