Results 1 to 7 of 7
Thread: DSATX Will Not Provide Power
    Apr 2007
    Punxsutawney, PA
    Power line supplies power, and when the car is turned on, the remote does as well, however, the DSATX will not output power through the cable. Any ideas? I tested the power and remote with a primitive signal tester (Basically just a light :-P)
    Apr 2001
    Portland OR
    Quote Originally Posted by Memphetic View Post
    Can you give a little more detail? Are you connecting up a motherboard? Is the motherboard pulling the green wire to ground? What is the LED doing? Have you read through the manual?
    -Jeff
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    Elsewhere
    Quote Originally Posted by zootjeff View Post
    The first question of every support issue.
    How about the Wiki?
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    user error
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Apr 2007
    Punxsutawney, PA
    In short: yes, I have
    Elsewhere
    That's hardly a sufficient test.
    Lay your hands on a digital multimeter (DMM) and test the voltage at the DSATX terminals for teh 12v constant and 12v switched. Test them both with key on and key off.
    How about the Wiki?
    Apr 2007
    Punxsutawney, PA
    I found out that the problem is actually that I'm blowing fuses. What could be causing this? My connections are fine - I have one fuse on the power line, and of course one on the DSATX. It appears random as to which one, but sure enough, one of them always blows when I reconnect the negative terminal to the battery. However, the one on my amplifier DOESN'T blow, which is what is weird to me.
  1. My DSATX 220w experience
    By tj!2k4 in forum Power Supplies
    Last Post: 11-16-2006, 08:47 PM
  2. DSATX Motherboard Power Switch Polarity
    By zootjeff in forum Power Supplies
    Last Post: 06-14-2006, 03:49 PM
  3. FS: DSATX 220 Watt Power Supply
    By Norrin302 in forum Classified Archive
    Last Post: 06-13-2006, 07:36 AM
  4. WTB DSATX Power Supply
    By dsballer2000 in forum Classified Archive
    Last Post: 06-12-2006, 07:53 AM
  5. DSATX 220w PSU Review
    By greenman100 in forum The Review Palace
    Last Post: 10-13-2005, 12:50 PM
