Parallel Bank
Hi all, what is required to set up two regulator circuits in parallel to enable higher wattage outputs? I've heard that this can cause devastating problemas with a power supply?
Is it just a case of isolating them from eachother... if so how would I do this?
Many Thanks
Dave
If they are just simple linear regulators you can put as many as you like in parallel as long as all the pins match up. As for switching regulators, i'm not too sure about that.
Best regards,
Matthew
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
