Back when I made all the mistakes in the world while setting up my M2-ATX, I had the +12v and IGN wires reversed, so it was pulling +12v through a 20 awg wire, and not only did the computer not boot very well, but the wire got very warm! With help from 2k1Toaster and Darque, I figured out that the wires were backwards and after I switched them it worked just fine (+12v is like 12 awg from amp distribution block).
Wire resistance makes a difference. Try running a larger wire (e.g., 8 awg) directly from your battery (make sure it's fused), and just use your cig lighter for the IGN wire. Also make sure your grounds are the same awg and short length.
LinkBack URL
About LinkBacks
